| I agree on the #316 nipples. All you really need to ensure is the proper welding rod( Stainless to mild steel, supplied by Unitor), and a good fillet outside and inside.Then wire brush thoroughly before painting. With the excellent two part epoxy paints of today like Jotun, you will not have any corrosion problems! Then put a proper stainless steel ball valve on the nipple. I prefer a three part body,(that can be stripped easily for servicing and repair) Good luck! Hannes |
| Repairing a steel hull | Jason Crum | Open Discussion | 11 | 04-21-2009 11:56 PM |
| Is there a problem with concrete as ballast in steel sailboat? | hiracer | Metal Boat Building | 6 | 07-24-2006 10:01 PM |
| Wanted: bluewater steel sailboat plans | horleywood | Boat Design | 4 | 12-28-2004 07:06 AM |
| Steel Hull Builders | PADDLEGUY | Metal Boat Building | 2 | 11-04-2004 11:55 AM |
| Steel sailboat mast | Gerald Niff | Boat Design | 4 | 08-11-2004 07:10 AM |
