Old 12-15-2007, 02:01 AM
42 below 42 below is offline
Rep: 10 Posts: 10
Through hull fittings
Hi
I am currently refitting a Roberts steel ketch and was looking for some advice!
The question is do I paint the boat before I put my through hull fittings in?
Cheers Doug
Old 12-15-2007, 11:30 PM
Kay9 Kay9 is offline
1600T Master
Rep: 279 Posts: 615
No, through hulls first, then primer and paint.
Old 12-15-2007, 11:46 PM
Rep: 10 Posts: 10
Cheers Kay 9
Old 12-27-2007, 10:55 AM
SteelTrawler SteelTrawler is offline
Rep: 30 Posts: 11
I am curious, what are your thru hulls made of?
Custom Advantage Marine
http://customadvantagemarine.ca
Old 12-27-2007, 03:35 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1544 Posts: 1,138
only when it is welded on...
Any other through hull fitting that get screwed on, prime and paint first before fitting.
Wynand
A scatterling of Africa
Old 12-27-2007, 06:30 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
Kay9,
I've got no experience at all with steel hull construction, but I'm surprised (if not welding the through-hull in) that one wouldn't sand rough hole edges, prime at least inside and out with epoxy, and then attach the through-hulls. This, I would think, would protect steel from corrosion/electrolysis better. I'm not saying I know this is true, but only want to know why not.
Alan
Old 12-27-2007, 06:41 PM
1600T Master
Rep: 279 Posts: 615
No, you guys are right. I assumed he was putting steal through hulls in. If not welding in through hulls paint first.
K9
Old 12-28-2007, 12:33 PM
Rep: 10 Posts: 10
Thanks chaps,
The through hulls are stainless steel PSP fittings! and we are installing (welding) before paint.
thanks
Old 12-28-2007, 06:05 PM
erwin.tarr erwin.tarr is offline
Rep: 29 Posts: 28
Rhino Liner?
A little off topic but related to coatings...
Have any of you tried having a "Rhino Liner" style polymer sprayed on the interior surface? It seems that it should work. What do you think?
Ray Tarr
Patrick AFB, Fl
1963 Allied Seawind, Crackertail
Hull # 25
Old 12-28-2007, 11:40 PM
1600T Master
Rep: 279 Posts: 615
What surface?...Wood, steal, GRP.??
Old 12-29-2007, 12:00 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
I have a better suggestion. My Roberts steel hull had stand pipes to bring the water inlet cocks up to sea level. This is the best idea since sliced bread.
Your boat wont sink and you can take the cocks off (with a bit of slop) to overhaul them should you so require.
Any blockages can be cleaned out without going in the water. If you use a ball valve you can also clear by roding straight through. KIS
Old 12-29-2007, 06:53 AM
Rep: 29 Posts: 28
Rhino Liner?
In referance to Kay9's question, steel hull. I was juat thinking that if Rhino Liner works so well on trucks, it might work on hulls. I know they provide a lifetime guarentee. My only concern would be trapping moisture or rust under the polymer. It would be a bugger to get to once dry.
I have a chance to get a steel hulled sailboat with a beautiful interior for a song-and-a-dance but it needs 30-40% of the plating below the waterline replaced. Do any of you have any experience in this?
Also, if and when complete, I will be selling my 30 foot Allied Seawind pilothouse in case anyone is interested...
Ray Tarr
Patrick AFB, Fl
Hull # 25
Old 12-29-2007, 07:11 AM
Rep: 29 Posts: 28
stand pipes
What an amazing, simple, and "why the heck doesn't everyone do this" idea. All three of my seacocks are stuck in the open position on my Seawind and I am worried ever time I go sailing. Unfortunately, I can't change the seacokcks unless I put her on the hard (an expensive proposition).
Ray Tarr
Patrick AFB, Fl
Hull # 25
Old 12-29-2007, 05:39 PM
1600T Master
Rep: 279 Posts: 615
Erwin.
Yes I can help you out with some free advice on replaceing steel on your hull, your more then welcome to e-mail me or we can talk here.
wbcaptain at charter dot net.
As far as the rhino liner goes. I cant think of a reason it wouldnt work. Like you say it will be hard to get to if and when it corrodes, under it. So I guess that would make me think twice about doing it. I do not believe there is anything you can do to prevent rust on a steel boat. So my way of thinking is that I want access to be able to do preventive painting and scaling so that I can keep the rust in check.
K9
Old 12-30-2007, 01:41 AM
Wynand N's Avatar
even some production yards uses them. check this link.http://www.caliberyacht.com/Website_..._Main_Page.htm and search for the "safety sea chest" down the page
Wynand
plastic fittings. Frosty Powerboats 12 04-05-2007 11:59 PM
Ballast tank fittings T.N.Todd Marketplace 0 03-01-2006 04:46 PM
CE: Through-hull fittings on aluminum boats Eric Sponberg Metal Boat Building 2 04-05-2005 11:21 PM
CE: Through-hull fittings on aluminum boats Eric Sponberg Boat Design 7 04-05-2005 09:06 PM
thru-hull fittings Sailboats 3 09-14-2002 10:33 AM
