Old 12-10-2011, 06:00 AM
naupigos_gr's Avatar
naupigos_gr naupigos_gr is offline
Rep: 11 Posts: 31
thickness calculation
How I can calculate thickness (t) of my plates in case i know the maximum bending stress?
I also have a chart with components of a the midship section( girders, deck plating etc etc) with dimensions, levers, 1st and 2nd moments of area, for each component. But everything is bonded with "t".
My given maximum bending stress given is 160 MN/m2
160 x 10^6 N/m2.
thanks and best regards
John
Give me a place to stand, and I will move the Earth
Old 12-10-2011, 07:04 AM
Olav's Avatar
Olav Olav is offline
cand. arch. nav.
Rep: 337 Posts: 198
Maybe I got you wrong, but the bending stress you talk about (longitudinal strength) is just one of several areas of strength/scantling calculation that need to be performed. Think of loads normal to the plate surfaces due to static and dynamic (= slamming) water pressure, deck load etc.
I suggest you make yourself familiar with the scantling rules of a classification society (personally, I'm quite comfortable with Germanischer Lloyd, but any other class will do as well) which allow you to calculate plate thicknesses according to your inner structure (i.e. section spacing etc.), type and intended use of the vessel, material properties and so on.
To satisfy the longitudinal strength requirements those rules will demand a minimum main section modulus, so you have to check if your design meets this demand and increase plate thickness (usually of the uppermost deck) or use larger longitudinal stiffeners if necessary.
All the best, Olav GER-1045 ____/)_/)/)___
Old 12-10-2011, 07:15 AM
Rep: 11 Posts: 31
thanks for your reply.
well its just an coursework with assumptions it will not be applicable to "real life" . he just gives as the maximum bending stress and says make the table with regards to t(which is an unknown) and then calculate it through the maximum bending stress (160 NM/m2)
I asked here, because professor is not the best you can find if you know what i mean
Resistance calculation and propulsion calculation for tug boat sreejith Props 0 02-06-2010 03:43 AM
Ply thickness Trevlyns Boat Design 2 11-13-2006 11:36 PM
plating thickness? rlackey Boat Design 31 07-17-2005 05:18 PM
Fiberglass thickness? welton Boatbuilding 2 07-22-2004 11:13 AM
blade thickness andy123 Boat Design 1 01-29-2004 08:42 AM
