Old 12-03-2011, 04:38 AM
Dutcher Dutcher is offline
Rep: 10 Posts: 15
Test drive aluminium speedboat and question
Hi,
I designed an aluminium speedboat and built it with a friend of mine. Last weekend we made a testdrive and this went very wel.
Via the link below there is a movie of the testdrive.
http://youtu.be/Shb9YfsjNrg
I have a question: Besides the testdrive showed good handling and speed there is a lot of fast water spray coming out under the chines especially when turning.
Would it improve performance (speed) and decrease spray to add 1 or 2 sprayrails on each side of the bottom in order to break this spray earlier?
Thank you,
Michel
Old 12-03-2011, 06:16 AM
Bottoms Up Bottoms Up is offline
No you need actual lifting strakes ,not splash rails. They spray is the hull cutting the water in half with more strakes it will be diverted to them and more lift,they should run forward to the stem.......
Old 12-03-2011, 06:51 AM
Rep: 10 Posts: 15
Sry, i mean lifting strakes. Do you think diverting the spray earlier reduces drag?
Antique drive question Captain Silver Propulsion 6 01-14-2009 07:17 AM
V Drive Question bentshaft Inboards 0 03-28-2008 11:40 AM
Ply boil test question maddyfish Materials 2 02-01-2006 09:06 PM
Velvet Drive Question DOGGYDOO DIY Marinizing 13 11-10-2005 10:30 PM
Aluminium or Fiberglass speedboat? Baneng Materials 9 11-07-2005 06:27 AM
