Old 08-07-2006, 08:03 PM
hiracer hiracer is offline
Rep: 27 Posts: 158
Stupid question
I am in the process of purchasing a steel sailboat. During the survey, four of six zincs were gone. I had some zinc plates drilled and installed because the yard did not have the right kind in inventory.
The bolts used to secure the zincs were shot too. A trip to a local shop gave me the option of zinc covered steel bolts or stainless steel. The yard recommend SS; I purchase the zinc covered steel bolts.
Did I do wrong?
The boat must come out for a paint job in a few months, so I can correct the situation soon, i.e., proper tear drop zincs and change the bolts if required.
TIA.
P.S. The ultrasound found NO hull material missing. Boat is five years old.
Old 08-07-2006, 10:16 PM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
The stainless (I think) is more noble than regular bolts. Both types are more noble than the zincs. I can't see where it would make much difference other than to the yard for selling more expensive items. Maybe speaking with some of the local commercial fishermen running steel boats would be in order.
Old 08-08-2006, 01:32 PM
jehardiman jehardiman is online now
Rep: 1623 Posts: 1,483
For the zinc's to work, they need to be in good electrical contact with the hull. How are they bolted on? Best practice is to shoot a CD stud (steel or CRES) after painting the hull, touch up the paint, bolt on zinc with a bedding of zinc paste around the bolt/washer/nut. Replace the studs as needed. As for myself, I wouldn't recommend SS bolts on a zinc. There are electrical potential , crevice corrosion, and hydrogen embrittlement issues depending on what SS class is selected.
Old 08-08-2006, 02:25 PM
Rep: 27 Posts: 158
There is a metal plate welded to the keel and hull to accept bolted on zincs. The yard ground flat the steel plate so the zincs would have a good connection to the hull.
I will see about getting the the zinc paste. I didn't use SS because of the crevice corrosion issue and electrical potential. Glad I was thinking correctly.
This metal boat stuff is all new to me.
Old 08-08-2006, 09:31 PM
timgoz's Avatar
Check out the internet for some books on steel boatbuilding. By reading 3-4 different ones you'll get several views which youy can pick & choose from. I've personally accumulated 4 that I can think of; one by Colvin, Bruce Roberts, "Steel Away" by Moir & Smith (I think), and Kringil (SP?) a small hard back obtained from Robert's. There are many others I have been made aware of through the net.
Though you already have a boat, the knowledge obtainable through good books will prove very useable in living with a steel boat in the longterm.
TGoz
Old 08-08-2006, 09:40 PM
SeaSpark SeaSpark is offline
Rep: 96 Posts: 593
Book: Metal Corrosion in Boats
I have this book in my lib, it's very clear and informative, not specifically for steel boats .
http://www.amazon.co.uk/gp/product/0...e=UTF8&s=books
Synopsis
The second edition of this book is intended to be of use to boatowner and boat builder alike, giving advice on problem areas such as keel bolts and propeller shafts. Engines, outdrives, copper sheathing and chromium plating are examined, and strategies are suggested for reducing or preventing corrosive effects.
Old 08-08-2006, 10:07 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,518
I would never drill a hole through a hull umless I really had to. My steel yacht that I used to have had bolts of similar metal as the hull. These were welded on at there heads. the anodes were then bolted to them.
Old 08-09-2006, 12:05 PM
Rep: 27 Posts: 158
Thanks. Funny thing, have several books on metal boats but they have been in storage in Alaska for the past five years. Ironically, today I leave for Alaska where part of the activities included packaging about 30 sailing books and shipping them back here.
BTY, I have another book on metal corrosion in boats, and it's fantastic. I just haven't had time to fully digest it. It's new. I'll post the name and author in a couple weeks when I get back.
Thanks to all for the help.
Old 08-09-2006, 06:21 PM
timgoz's Avatar
Hiracer,
Where are you heading to in AK? I got to spend a couple of summers up in SE AK, one in Ketchikan & one on the norht end of Prince of Wales Is. around Port Protection.
TGoz
Old 08-18-2006, 03:30 PM
Rep: 27 Posts: 158
Just got back. Visited in-laws in Anchorage.
Check out my old boat in Seward. Sure do miss the sailing and cruising there.
Just purchased yesterday a metal sailboat with intended use to cruise SE Alaska once we retire (in about a 100 years from now).
Going to buy a chart of San Juans Island now. Later.
Old 08-19-2006, 08:55 PM
Rep: 1623 Posts: 2,343
Hiracer
Read my attached file. Feel free to ask any questions
Cheers
Mike
Mike Johns.
Please knock down stupid idea VT-tuna Boat Design 50 07-17-2006 03:47 PM
Call me stupid... Sean Herron Boat Design 17 04-08-2006 04:04 AM
Stupid Question McBoo Open Discussion: All Things Boats & Boating 29 12-27-2005 07:31 PM
Just Stupid... Sean Herron Boat Design 18 02-06-2005 11:53 PM
"Stupid" Epoxy /polyster question... ErikG Materials 5 05-01-2003 01:39 AM
