Old 05-09-2011, 05:14 PM
Dean Smith Dean Smith is offline
Previous Member
Rep: 0 Posts: 0
Originally Posted by Nick.K View Post
Many thanks for all the replies.
Ad Hoc
Yes, I meant class approved steel.
"The most basic is called either Grade A, or J235 or JR235 or S235 steel depending upon or stockist/mill supplier. This conforms to BS EN 10 025 (1993). It is this that is commonly used in shipbuilding.
The J235, JR & S235 are grades that are sold as construction steel and grade A is the same steel that has been approved by Lloyds for ship use. Is this correct?
Can you recommend a concise source of information on the web about what these grades mean?
Dean
I was planning to blast after completion of the welding and use Jota mastic direct on the blasted surface by airless spray. Will take up your offer of welding advice.
The hull was built in Holland around 1985[/quote]
ok, do you have a plating plan? sketch it up and let,s see it
Is it possible to build in steel if not originally designed for steel? eggman918 Boat Design 16 01-17-2011 03:39 PM
structural changes taezow Multihulls 17 09-07-2010 12:04 PM
Free of charge, Steel - polyurethane foam -Steel insulation sheets rossgiles Fiberglass and Composite Boat Building 0 03-18-2008 06:43 AM
A structural question ... ath Sailboats 10 06-10-2005 06:12 PM
Structural foam? skypoke Boat Design 7 01-05-2004 05:39 AM
