Old 09-15-2004, 06:53 PM
Michael Devlin Michael Devlin is offline
steel specification
What is correct specification of steel for boatbuilding, i.e inland waterway barge.
Old 09-16-2004, 03:03 AM
Rep: 66 Posts: 640
For that I need to know what type of steel it is, then I can give you the specification.
But for your info, the most common steel used in shipbuilding is: Grade A
Chemical composition:
Carbon 0.21% max.
Manganese 2.5XC% min.
Silicon 0.5% max.
Sulphur 0.035% max.
Phosphorus 0.035% max.
Carbon and 1/6 of Manganese content is not to exceed 0.4%
Mechanical properties:
Yield 235 N/mm^2 min.
Tensile 400-520 N/mm^2
Elongation 22% min.
Hope this helps.
Dutch Peter
Old 09-16-2004, 08:43 AM
Sandy McKerrow Sandy McKerrow is offline
Rep: 10 Posts: 5
Michael,
You might get a few blank stares if you mention shipbuilding Grade 'A' steel, especially for inland waterway (narrowboat?) specifications.
Stockists usually respond better to the old (defunct) BS 4360 specification, grade 43A which I seem to recall as being the equivalent of grade 'A', or a little better. The "new" standard is BS EN 10025: 1993 grade S275.
However, recommend you make your own enquiries with a local steel stockist. No point in recommending all sorts of specifications if it is not available in your area.
Old 09-24-2004, 07:55 AM
Paruchuri_111 Paruchuri_111 is offline
may i know the complete details of steel boat engine and fixing ....
Old 11-29-2004, 08:06 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
Dutch Peter is right, grade A would be best, but is slightly more expensive than what i might propose: if it's a regular barge for inland waters use steel commercial quality tensile strength between 37 and 42 also callesd ST 37 - ST 42.
Durable Steel Hulls Wynand N Metal Boat Building 11 01-27-2009 07:19 PM
Aluminium vs Steel Wynand N Boat Design 78 09-20-2007 08:34 AM
Stainless steel / Aluminum hendrikus Boatbuilding 5 06-30-2006 07:40 PM
255' Three-Masted Steel Barkentine for sale Yachting Marketplace 0 02-09-2005 10:35 PM
Steel and plywood hull? pdvjak Boatbuilding 1 02-02-2003 12:12 AM
