Old 08-10-2004, 12:03 PM
minstrel minstrel is offline
Rep: 10 Posts: 2
steel hull house boat restoration
i have a 100 year old ,80 foot steel hull houseboat on a high mud berth. she has a rusty hull and a number of holes below the water line. she floods to a inside depth below deck of about 5 foot 1 hour each high tide. so only the upper deck is now habitable. the main deck is concrete and about 40 years ago the owner put a concrete bilge in to stop her from moving in the mud berth. question; can i repair her from the inside, tank her out just to keep the water out.she will never need to float from the mud. either steel plates the ribs are fine or a concrete render with a mesh and waterproof membrane.. thanks .. steve
Old 08-11-2004, 04:06 AM
Rep: 66 Posts: 640
Steve,
Repairs can be made from inside. Depends a bit on the location. Are the holes in the side or bottom shell? You could try welding doubler plates. Personally, I consider concrete as a temporarily repair.
Regards,
Peter
Old 08-26-2004, 05:48 PM
Sandy McKerrow Sandy McKerrow is offline
Rep: 10 Posts: 5
Are you sure the hull is steel? More likely to be rivetted wrought iron construction if your estimate of age is right
Old 08-30-2004, 09:40 PM
Rep: 1623 Posts: 2,343
I've seen a few rustly old hulks rejuvinated by attaching a mesh and chicken wire over the outsides and plastering it with sand/cement/pozzilan. This can be done over a rotten structure that could not otherwise be repaired with a good strong lasting result. With a rapid set additive to the plaster mix this can be done between tides. Trouble is you have to be able to access the outside of the hull. Sounds like yours is probably sunk in the mud.
You didn't say whether you were in salt or fresh water in your tidal zone.
You can tell whether its iron or steel simply by the colour of the sparks from an angle or bench grinder. If its steel and you have good enough surrounding plating, it would be easy to repair by anyone with a welder . Some old irons are hard to weld successfully .
Mike Johns.
Old 09-03-2004, 01:46 AM
bud1000
if the steel is weldable.......and i would doubt it considering the age you quote...... you will need a good qualified welder to do this work..... rusty metal is a horror to weld and repair..... and the tradesman you hire will be cursing your very existance every minute of the job......grins
Jet Drive Jet Drives 15 12-18-2006 10:51 AM
Steel and plywood hull? pdvjak Boatbuilding 1 02-02-2003 12:12 AM
