#31
| Sheet foam is a big mistake. I tried it and the steel was permanently wet behind it ,regardless of any vapour bariers I tried.It costs about the same a spray foam and fitting it is a huge job. I plan to be in Nanaimo in the next few days . I built a hull last spring which is at independent shipyards in Coombs.I should be able to finish it this summer . I'll try contact you when get to Nanaimo.I wouldn't mind a look at your project. Brent Swain |
| How about boat design definitions | JonathanCole | Boat Design | 55 | 01-24-2010 05:48 PM |
| Jet Drive | Jet Drives | 15 | 12-18-2006 10:51 AM | |
| Building model...questions on hull design... | bduly | Boat Design | 6 | 03-29-2006 08:44 PM |
| Steel and plywood hull? | pdvjak | Boatbuilding | 1 | 02-02-2003 12:12 AM |
