| steel hull 36ft restor any one give me some advice? on the steps to the restoring of a steel hull ,its been sandblasted, and looks to have been sealed with some paint , yes this is my first project boat ![]() what i'd like to know is the 1st step =sandblasting 2nd step=sealing the metal (primer ) what type? eitch ,converter 3rd step= ? some sort of coating ? apoxi? 4th step =coating of paint is the idea to paint the hole hull then paint the anti fouling over it? or anti fouling to the water line, paint up from there? any ideas wellcome , like to see the differant ideas from peoples ![]() mainly just want to get more of an idea then i have already of what i might be getting my self in to things other might have done what the good times and bad times are like hehe cheers ron thanks guys and gals (ofcourse) |
| Here is a link to my standard paint spec for steel boats - too much to copy here: http://www.fairmetalboats.com/coatings.htm |
| cheers paulM checking it out now |
| another way! Hi For what it's worth ! Blast the hull to SA 2.5....Paint the entire boat with Zinga and then apply any topcoat you wish...Your hull will never rust and recharging the zinga every few years is a piece of cake....check out Zinga (belgium) on google...no antifoul required and the stuff is inert....you can eat it they say! Good luck...Paul |
| ripper mate looking into it now and its always worth another a better way "zinga"? it like got zinc in it? and you got a web address on it cheers ron |
| Steel can rust and protecting it is extremely important. Zinc is commonly applied to steel to prevent it's corrosion by rust. This is done by hot dip galvanizing and /or zinc spraying. This process requires that you send the part out to a specialty shop. Further, hot dip galvanizing creates a zinc-iron alloy which is brittle. How would you like a liquid that could be sprayed, brushed or dipped like a paint and have it protect like a galvanized zinc coating? In fact, how would you like a special formula that has been used widely throughout Europe for the last 26 years and which the U. S. Army has successfully tested on trucks in Hawaii. ZINGA is such a formula. Applied wet, this remarkable coating system dries to over 96% pure zinc and is scratch and corrosion resistant. Imagine, you can spray, brush or dip Zinga on your steel structures, welds, fencing, towers, cables and it will protect for years against: |
| sounds interesting cheers paul |
| Don't put any zinc or aluminium based primers below the waterline. just epoxy and antifoul. Inside Zinc it with any tough zinc rich primer then epoxy. Same for topsides and deck.
| Is the hull perfectly formed? Maybe you should add a faring step before painting. Rich Murray North Weymouth MA |
| Shotblast to Spec SA2.5. Immediately cover with epoxy primer. Use the same complete epoxy paint system (make, manifacture) for overcoats. Follows the manufacturers notes and overcoat times religiously. Spray complete hull, above and below waterline, then apply antifouling. Use coal tar epoxy on the inside of hull, apply thick - 140+ microns. Use an airless spray outfit if possible. Remember your sacraficial anodes on steel hull to combat electrolysis. Wynand Nortje |
| How about boat design definitions | JonathanCole | Boat Design | 55 | 01-24-2010 05:48 PM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| Jet Drive | Jet Drives | 15 | 12-18-2006 10:51 AM | |
| Steel and plywood hull? | pdvjak | Boatbuilding | 1 | 02-02-2003 12:12 AM |
