Old 02-19-2006, 08:47 PM
RDB RDB is offline
Rep: 60 Posts: 48
Steel framing interior?
I have been asked to assist on the interior layout of a 55' trawler and had a few questions about interior framing. When constructing aluminum yachts around 40', we would often frame up the interior walls, beds, and strorage areas in square tubing so that the interior joinery was much easier. Is this pretty much common practice with steel as well? Also, the heads used to be plated, faired, and painted in aluminum for the shower and whatnot. Whats is the norm for heads in steel boats? Any advice would be greatly appreciated.
Thanks
Old 02-19-2006, 09:50 PM
Rep: 505 Posts: 1,658
dont know about the norms for heads in steel boats but when ever you combine steel and aluminum or any other metals, you magnifi electrolisis
Old 02-20-2006, 04:18 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
From what I've read, you should be able to use exactly the same techniques. I think you can actually get away with using a mortar-grout type mix for fairing in a steel hull. I'm told that mortar and steel have the same expansion characteristics.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 02-20-2006, 05:24 PM
just like bridges!
Old 02-21-2006, 07:56 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
I've found that drilling holes in the ribs and screwing wood 'cleats' bedded in a bit of sticky is fine. You then fastens the lining/ceiling to the cleats! Well it works for me! Or bolts for the bigger bits!!
Old 02-21-2006, 11:17 PM
RDB RDB is offline
Rep: 60 Posts: 48
cheers. Thanks for the tips
Old 02-22-2006, 04:01 AM
Rep: 1623 Posts: 2,344
RDB
Generally with steel vessels the interior joinery frames etc are from L section steel rather than RHS. RHS would need to be sealed both ends.
For the Head dont plate in steel as you describe it will rot out eventually.
You can use alloy or stainless steel and bolt it to the sub framing. Provided its painted and out of the bilge there will be little trouble with galvanic corrosion at the joint, always think which metal is likely lower on the galv scale and make its lug the beefier one.... corrosion allowance . On steel vessels you should leave good ventilation and inspection access around potential wet areas and potential corrosion spots. These days the epoxy paints are so good that internal dissimilar metal joints seldom show any problem providing thay are not in water. External is a different story.
Mike Johns.
Looking for help with interior.... stant1man Powerboats 1 08-05-2005 12:32 PM
Looking for some help with interior... stant1man Boat Design 0 08-02-2005 12:16 PM
Simplified powercat alloy framing? skypoke Metal Boat Building 6 03-07-2005 01:20 PM
New Steel 70' Interior Yacht Proposed Layout THERIAULTMARINE Metal Boat Building 0 08-30-2004 09:16 PM
Interior Design greco Boat Design 1 01-29-2004 01:21 AM
