Old 02-22-2006, 10:45 PM
H20fwler H20fwler is offline
Rep: 10 Posts: 26
starting out
I am wanting to start learning to weld aluminum.
How much (ballpark) will it cost to get started. I have a cheap MIG welder that I used to fix sheet metal on cars and some small projects. I know I will have to change gas tank but can I get by with a cheap welder to start??? I know it will not be the best but I do not want to sink 2K in starting.
Thoughts?
Old 02-23-2006, 03:30 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
It depends on how hard you're going to wail on the welding. you could destroy a cheap machine in a matter of months. But if you're just practicing, it should be fine (pay attention to the duty cycle for your particular machine). You should practice alot because aluminum it as easy to weld as two sticks of butter (I exaggerate). Switching over from your little machine to a good one might cause you to stumble a bit if you're really busy.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Starting a project Magellansoul Wooden Boat Building and Restoration 5 11-07-2005 09:45 PM
Just Starting Out H20fwler Metal Boat Building 3 07-14-2005 12:45 PM
Restoring an old boat, starting with the floor. jsass Boatbuilding 7 06-24-2004 09:56 PM
Hard Starting boater-rick Powerboats 4 01-15-2004 11:15 PM
Starting out in Performance Powerboat Design Archive Education 5 01-25-2002 08:47 AM
