| Strength in the seats I have a 14' aluminim quintrex boat with three bench seats an i've taken the middle and back seats out to put a floor down,but now i've a lot more room i would like to leave them out.So how strong would the sides be without seats,plus i know i will loose flotation but i'm more worried about strength.PHIL. ![]() Last edited by philzero44 : 03-25-2008 at 09:37 PM. Reason: adding picture |
| philzero44, Why not phone Quintrex and see what they suggest, their "bass" style boats have just landings in them and they are great, they may have some very good ideas for your job.
| Philzero, I'm sure they'll provide you the standard, "can't be responsible reply" and that it's "not recommended". The legal department forces them to do this. It's very probable you've removed a substantial portion of the athwartship stiffness, when the seat was taken out. You could stiffen the area up by enlarging the structural elements that create the sheer and chine. ![]() The sheer is pretty flimsy, she's just a stamped metal boat, so you'll probably want some "knees" in the area of the old seat boxes. You can use the outboard corners of the old boxes to make these knees, or make new ones yourself. Just cut off the boxes, but leave an angled corner of the seat boxes in place along the lower outboard sides. This will give you four angled, triangled braces, between the sides and bottom of the boat. Box them in, by riveting, gluing or welding (if you're really a good welder) a plate over the two remaining corners (each side of the boat). This will support the sides well enough, but the bottom will be flexible. Leaving a small portion of the center section of the box will dramatically help the weakened bottom, especially if it was boxed in like I described on the chopped down corners. |
| project with seats | ranMan | Boatbuilding | 3 | 01-21-2007 10:06 AM |
| interior seats | roadking666 | Materials | 0 | 10-28-2006 08:13 AM |
| Dimension of seats and feet clearance | jfblouin | Boat Design | 3 | 03-28-2006 02:51 AM |
| Interior construction (seats) | freeagent | Boatbuilding | 0 | 12-29-2004 10:49 PM |
| Recover Boat Seats | KimC_Denver | Materials | 4 | 04-21-2004 11:48 AM |
