Old 12-10-2005, 08:31 PM
dandude dandude is offline
small boat plans in aluminum
hi all,
i am looking to build a small rowboat such as a dinghie,or tender in aluminum.8'-12'
but iam not finding any plans for that small of a boat.
i have built a ken hankinson plan before(15' driftboat in wood) and liked his plans but he is no longer available.
for my needs the simpler the better!
thanks for any help! dan
Old 12-11-2005, 03:44 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
If you find plans for plywood, you can probably use them. You may have to add more stiffeners, frames or longitudinals.
In Holland they make dingies of this size in steel.
Maybe you can find some drawings there.
If you don't find anything we can help you make one :-)
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 12-11-2005, 10:08 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
http://instantboats.com
Bolger/Payson boats tend to be remarkably simple to build, most are for sheet plywood construction but almost all can be readily adapted to aluminum.
Glen-L has a few too that you might be interested in; http://www.glen-l.com they offer a few plans in metal as well as wood.
Old 01-20-2006, 05:52 PM
Pavel Pavel is offline
Rep: 15 Posts: 21
Alu dinghy
Hi we had a similar thought during last summer and adapted Dave Gerrs plywood Nester to aluminium:
http://www.sailjoohee.com/Building/Nestor/nestor.htm
the boat is not quite finished as yet but it floats rather well.
Pavel
Old 01-20-2006, 10:11 PM
Deering Deering is offline
Rep: 14 Posts: 219
Check out the plans from Sam Devlin. Plywood but easily modified for aluminum. He's in WA with you. Google him.
Old 01-21-2006, 12:02 PM
sal's Dad sal's Dad is offline
Atkin/Bolger fan
Rep: 80 Posts: 109
I built a Bolger Teal of 1/8 aluminum plate a few years back - see the instantboats website referenced above. Heavy (weighs about the same as 3/4 ply) but indestructible, and zero maintenance.
As long as the panels are curved, and supported on all the edges, there is little need for stiffening. The flat panels, on the other hand...
I think you could do just about any plywood stitch-and-glue boat out of aluminum. Anybody for an industrial-strength kayak?
Sal's Dad
Old 01-21-2006, 12:39 PM
hoagey hoagey is offline
Rep: 10 Posts: 14
Try this Dudley Dix design. It can be built in aluminum for those who have the skills.
http://www.dixdesign.com/dinghies.htm
Old 01-21-2006, 05:15 PM
Raggi_Thor's Avatar
We make laser cut kits of these dinghies in plywood or alu :-)
www.MBOATS.no
Need to build a 18ft Aluminum Boat myles king Boatbuilding 1 06-24-2005 11:20 PM
kit boats - boat plans aS__iS Boat Design 7 06-06-2005 03:40 PM
aluminum jet boat design gray webber Boat Design 0 11-27-2004 01:09 PM
Aluminum jet boat design? gray webber Powerboats 0 11-27-2004 12:23 PM
Need boat plans (please help) EMporto Boat Design 1 11-22-2004 07:25 PM
