Old 05-24-2006, 05:30 AM
vishnubaiju vishnubaiju is offline
Rep: 10 Posts: 61
Small Aluminium boat
See this 5.1m Aluminium catamaran hull for reservoirs.
Length = 5.1m
Breadtrh =1.10
Depth =0.5m
OBM Power = 2.0 h.p
All welded craft. Contains 4.7% Magnesium.
I am palnning to increase the breadth of this craft, and length a bit to suit the form.
All comments are welcome
Small Aluminium boat-image-113-.jpg  Small Aluminium boat-image-119-.jpg  Small Aluminium boat-image-109-.jpg
Old 05-25-2006, 07:30 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Is the aluminum hull in the photos designed as one-half of a cat? Or is it meant as a really slim monohull? 5:1 length/beam is rather slim for a mono this size, but pretty fat for a cat. Are you planning to split it down the middle to widen it?
Old 05-26-2006, 12:31 AM
Rep: 10 Posts: 61
Monohull
Thank you for your interest.
There was some difficulty in getting a keel section at center. And welding very close may create trouble.So I wanted to fabricate keel from plates. The hull was made like a slim cat. But it is very sensitive -- rolls. It was difficlult to weld a bilgr keel also.
I am planning to widen at center and provide some more volume at sides also. The final breadth would be 1.8- 1.9m
To build small aluminium boats - Need advice ronyt Metal Boat Building 21 12-27-2009 02:47 PM
Aluminium boat design. profix Metal Boat Building 2 04-27-2005 01:13 PM
Pictures of steel and aluminium small crafts? Cigra Metal Boat Building 7 03-09-2005 09:33 AM
aluminium boat design profix Boat Design 2 09-30-2004 06:21 AM
Aluminium Boat Guest Metal Boat Building 8 06-08-2004 10:05 PM
