  #31
Old 02-01-2006, 04:04 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
Hey Ken theres an idea, get several old beat up containers, ship 'em to Indonesia, flog of expensively!
Use the money to finance a 'large expensive gin palace' and live happily ever after (if not a little bored 'cos you've done nothing) and gets us all as jealous as hell!
  #32
Old 02-02-2006, 04:45 AM
Wellydeckhand's Avatar
Wellydeckhand Wellydeckhand is offline
Previous Member
Rep: 36 Posts: 1,403
Why GIN? it surpose to come out from a LAMP...........sinful chap
  #33
Old 02-02-2006, 06:42 AM
sharpii2 sharpii2 is offline
Rep: 419 Posts: 854
I like your basic design. I would suggest just one minor change. That would be cutting about a 1/3d to 1/2 meter radius in both the bow and stern ends to make it easier to move about. Such an effort would add little to the cost and add much to the utility.
Everything else seems much within reason.
This vessel would have high initial stability but low ultimate stability, so any ocean crossing it would do would have to be on the deck of a ship.
Hell, I would even consider adding sails and a leeboards to this rig. (of course, I like to do that with just about everything that floats)
Bob
  #34
Old 02-02-2006, 03:11 PM
safewalrus's Avatar
Ancient Marriner
Hey Sharpii does that include beer barrels, then you could die happy!
  #35
Old 02-02-2006, 06:05 PM
jerryniff jerryniff is offline
Rep: 10 Posts: 17
Well, of course it includes beer barrels ..... didn't you notice that he is from Michigan.
I like the initial idea but am still not sold on the idea of corrugated containers as the part below the water line. Other than that .... why not. Guy on the other side of the island lives in a VW van placed on top of an old wooden fishing boat. Works for him and works for the women in his life. So ... what is the problem?
Gerald
  #36
Old 02-02-2006, 09:59 PM
Previous Member
What a waste of good aluminium.........doesnt mix well with container.
Should go around people's yard with permission of course ........ buying off cheap left over material .......That is more professional and economical in helping to buil the JUNK .........chinese boat or really bad term
Enviro Friendlio
WELIODEKIHANNA
  #37
Old 02-02-2006, 11:16 PM
safewalrus's Avatar
Ancient Marriner
Jerryniff, yeah as I've been saying all along nice box, nice house but not direct into the water put it onto a barge and we're laffing! Or sell the box to 'Welly' he'll buy anything! thenlive in the barge direct!
  #38
Old 02-02-2006, 11:36 PM
Previous Member
Mmmmm............Walrus .....U wont get a piece of action in Borneo river on landside . The girls prefer protection of the river as a barrier. .... too many walrus snooping.........
WellyDeckerhander
P.S. Is walrus Stalking allowed in England.......
  #39
Old 05-17-2006, 04:42 PM
SamSam SamSam is online now
Rep: 455 Posts: 1,606
One other problem with making a shipping container shantyboat, on the outside there is no bottom. The plywood floor on the inside is all there is besides the steel beams every foot or so that support it. Sam
  #40
Old 05-17-2006, 11:11 PM
SheetWise's Avatar
SheetWise SheetWise is offline
All Beach -- No Water.
Rep: 525 Posts: 243
Cut it in half (horizontally) -- 8x4x80, or 16x4x40. You've got at least two ready made bulkheads that are hinged!
Build something with less weight on top of it.
Time is Gods way to keep everything from happening at once.
  #41
Old 05-18-2006, 12:55 AM
Rep: 1397 Posts: 7,215
We do learn. Reinventing the wheel is more expensive than buying a used one. The amount of work and money on cutting, welding and modifying a container is higher that buying a used barge or boat.
  #42
Old 06-04-2006, 05:57 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
I'm not sure about the carbon content in the steel. Longevity might be shorter. I'd use coal tar epoxy for the coating.
Start with 2 8"-10" I beams longer than the container length. sit them on something cheap but smooth & flat for this will be the bottom of the boat. Plastic over graded clay (not sand), or 1/4" sheets of OSB. Weld from these the upturned frames for the bow & stern. Set them "in" 2' from the container edge. Add proper dross gracing between the 2 I beams add rebar & wire. Pour this space full of concrete fore to aft. Now you have a "ballast keel and a concrete bottom. Then add cross beams every 2' to the top of the beams & and fasten (bolt & weld) the container to them. This keeps the ballast weight LOW 7 Inboard from the edges of the container.
Inside, add 18' SUBFLOOR. sAME DRILL INSIDE. kEEP YOUR TANKS IN THE CENTER & AIR SPACE TOWARDS THE EDGES. eXTEND THE AFT STRAIGHT OUT FLAT ENOUGH TO MAKE THE ENGINES FIT THERE. tHEN SWEEP UP TO SUIT A PLEASENT LOOK. aDD THE RUDDER TUBE, DECK OVER AND MAKE IT SELF DRAINING. bOW GETS A CHAIN LOCKER & THE SAME LINES.
gIVE THE TOP A dUTCH BARGE OR FORWARD PILOT HOUSE CUT. rEMOVE THE REST, DECK OVER AND ADD RAILS. This helps the looks & that topheavy feel.
a LOVELY LITTLE DUCK ISN'T SHE!! yOU GOT ME ENTHUSED BUDDY, i'M INTO IT!(sorry, I hit the caps lock).
  #43
Old 06-04-2006, 06:17 PM
ted655's Avatar
Rep: 122 Posts: 641
ted655@fastmail.fm
Hi Ken.
Hey, I'd like to kick this idea around. It's a great idea. So if you need a bud & want to bounce ideas back & forth, mail me.
I think it was you who posted on the shantyboat group. My wife & I are searching for canal boats right now. We may buy one used or a "sail away" (motorized shell) over there and stay and cruise awhile. BUT.. now I'm infected with this idea!
Thanks, Ted.
  #44
Old 06-22-2006, 12:32 PM
Hammersmith Hammersmith is offline
Rep: 10 Posts: 3
I work with the crew of Scrapheap Challenge' (Junkyard Wars in the US) and they tell me the Chinese are building containers so cheap that it's not worth shipping them back empty from the UK. Tilbury has over 10,000 laying around the yards, and the price is at scrap, (under 400 pounds sterling). If a way could be found to coat them with old car tyres and power them with discarded mobile phones we could be on to a winner!
Richard
db Gideon, Hammersmith UK
  #45
Old 06-22-2006, 01:37 PM
ted655's Avatar
Rep: 122 Posts: 641
No kidding, thats for sure. Disposable diapers could figure in there somewhere. lol.
Incredible "Secrets of Yacht Design" website located... pkoken Sailboats 579 10-09-2005 08:33 PM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 03:03 PM
Production mold of "Lyle Hess" 40' Bristal Channel Cutter BRI Boatworks Sailboats 0 07-13-2004 01:08 PM
"Propeller pockets" or "Tunnels" 67-LS1 Powerboats 24 04-16-2004 06:08 AM
