Old 07-19-2004, 04:35 PM
Robert Gainer
Shaping Hulls
About thirty years ago a steel boat was being built, I think in Australia that was two football shaped pieces of steel fastened together along the perimeter with a charge of blasting powder between the halves. The assembly was put under water and after detonating the explosive charge the two halves were separated. One end was cut off each and replaced by a flat piece of steel to become the stern. You got two boats out of each setup. If I remember it right the shape was very nice. What ever happened to the technique? Does anyone know anything about this method of shaping hulls?
Old 12-10-2004, 03:22 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Hi Robert,
Yes, about 12 years ago I read an article in a magazine (cannot recall which) of a similar construction method in Australia. They actually formed the shape of the hull into the ground with concrete, lay the aluminium plate in and over shape, thrown in a couple of kilo's explosives, put the lid on, and ignite the big bang.
The hull is perfectly shaped and build in a flash. Should see the photos.
Yep, the Assies are a breed apart.
Fair Winds
Wynand
Old 12-12-2004, 05:50 PM
Rep: 1729 Posts: 2,462
It didn't work well enough to be a success, but it was an ingenious idea. The problem is the chance of ending up with an expensive boat load of distorted plate if it goes wrong.
Mike Johns.
Old 01-03-2005, 10:39 PM
Alan Gluyas Alan Gluyas is offline
Designer / Surveyor
Rep: 10 Posts: 8
The boat was a sailing vessel about 30 feet long and they called it a "dynamite 30" or "gelegnite 32" or something similar. I remember they used 3M VHB tapes to stick the hull longitudinals into the hull after the explosive shaping, to avoid subsequent weld distortion. I read a test on what I assumed was a production vessel, but I have never seen one. They were made somewhere on the east coast of Australia. One of the big problems I recall with this technique is controlling the flow of metal when it gets stretched. It easy to tear great holes in the plate if there is not enough metal. The former they used was made of 20mm x 20mm square steel bar only a few mm apart and they welded the alloy plate into an approximately boat shaped box before putting it into the former, filling it with water and then adding a few sticks of gelegnite.
As Mike said, it could be an expensive learning curve.
Old 01-04-2005, 02:26 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
This was a great method for shaping large metal components, and was used for making some of the components for the apollo lander. They had it figured out well enough.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 01-12-2005, 03:23 PM
Pavel
You can find a chapter about explosive forming in book called Boatbuilding with Aluminium by Stephen F. Pollard.
honestly: its not so impressive, I would bet for stretch forming instead of explosives. Anyone out there having money to finance a a stretch forming press with 1.5GT facility to form a nice 45 footer in one piece? I am in.
The Ideal Cruiser - a long range passagemaker D'ARTOIS Projects & Proposals 306 07-15-2011 06:54 AM
Jet Drive Jet Drives 15 12-18-2006 09:51 AM
ROCAT closed mould one-piece hulls cristofa Fiberglass and Composite Boat Building 10 07-15-2005 04:13 PM
A Tale of Two Hulls.... BCBoater Boat Design 6 09-05-2003 01:48 AM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-25-2002 11:26 PM
