| Runs in "high build epoxy" Not sure where to post this. I put on my first coat of High Build epoxy primer on a aluminum hull and have a couple spots with orange peel. Should I sand it out now or wait until after the next 2 coats go on? |
| jmac, get em out early, so thinners can escape from the thick ness, some times you can "shave" runs off with single edge razor held at roughly 90 degrees to suface & scrape, peel is often typical in high build primer depending on equipment used, I am by no means a full on spray painter but have done a goodly amount, beware of pissing the paint up with a fast thinners though in a cold climate, as on a metal substrate especially you can reach a dew point situation through solvent evaporation & epoxy dont like water till its cured, all the best with it & regards from Jeff. |
| I would go ahead a apply the next couple of coats and then sand. Don't worry about a couple of runs in the high build primer just do your build up then when done with your build then sand. Remember with epoxy primer you have a recoat window for high build. Awlgrip and Sterling reccommend 8 hours before having to sand between coats. Dan |
| It was not much so we sanded lightly and applied another coat. Sterling says recoat time max 24 hours before sanding is needed. We are in a cold climate inside a heated building so our room temp was around 70df and the boat metal was between 63 and 70d f. I dont see much literature on what the relative humidity should be when painting. |
| FSP "fiber spray putty" to build boats | pacoblasco | Materials | 10 | 12-09-2006 08:02 AM |
| old heavy"lugger" vs high reving & more hp | globaldude | Diesel Engines | 26 | 11-01-2006 03:38 PM |
| I Would like to build a rib"looking for mold for it " | johndasilva | Boat Design | 3 | 06-06-2006 04:01 AM |
| Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" | Vibtor | Software | 0 | 10-02-2004 03:03 PM |
| "Stupid" Epoxy /polyster question... | ErikG | Materials | 5 | 05-01-2003 01:39 AM |
