Mollymawk
New Member
- Joined
- Jan 23, 2011
- Messages
- Reaction score
- Location
- on the High Seas
Hello,
We live aboard a steel boat, and one annoyance is that the gets so cold as to be very unpleasant to sit on at night, or even to stand on when on night watch (we have to use rubber mats and/or wear shoes). Of course, this problem will only get worse as we travel to higher latitudes.
One solution we are considering is building a wooden lining to the cockpit, however I am not a big fan of this approach. And it still leaves the rest of the deck being cold.
A few days ago I mentioned the problem to Nick Skeates. He told me that he once came across a steel boat which solved the problem by using a rubberised paint with rubber dust - ground-up car tyres - mixed into it.
Apparently the deck didn't feel at all cold, as this paint provided enough insulation, and it was also very durable - apparently the owner showed this by dropping a winch handle from head height onto the deck to show how it bounced off!
I am, naturally, very curious about this coating and wonder if anyone has any experience of it or knows what sort of paint might work.
I would have thought that the rubberised paint might not adhere very well to the hard paint below (epoxy or polyurethane), and that this might encourage rust underneath due to trapped moisture. I would also have thought that the coating would have to be very thick to provide the desired insulative properties which would prevent the deck from getting so cold.
I have searched the web without finding much of relevance; the closest thing being MikeJohns' comment in a post on this forum which mentions using rubberised swimming-pool paint for its non-slip properties. I wonder if it also makes the deck warmer to the touch as described above?
Thanks,
Caesar
Thanks,
Caesar
