However, using "off-the-shelf" products, minimal personal and anecdotal testing, backyard environment and skill-sets, and very low production runs (think: 1) caution is appropriate. Particularly in an evironment every bit as risky as flying. When I am out with my family in colder water conditions, a major seam failure below the waterline would mean near-certain death. Again, if anyone has real information or experience, please share it! Sal's Dad |
Vastly different situations - your analogy is poor. Planes are built to rigorous standards. The longest flight for any passenger jet is about 15 hours - nearest airport usually less than a couple of hours away. They are generally in a dry, low corrosive environment. The only real load the hull experiences is during take off and landing. And some thermal cycling once a flight. By comparison boats are typically built to much less rigorous standards - certainly most leisure craft. They are continuously exposed to the most corrosive environment. They could be on a voyage for many months with the nearest land weeks away. They could be exposed to high stress cyclic loading for days on end. I fly most weeks but each take off I still wonder if it will be the last - so maybe I am a pessimist. I fly for my paid work. These are the things I think about because I have seen the way cracks are controlled in plane structures. Irrespective I still would have much greater concern setting out to cross an ocean in an aluminium boat relying solely on glue for its structural integrity. Rick W. |
| I have used a 3M epoxy several years ago to glue aluminum together - not for a boat, but for some electronics. I remember testing several epoxies to see which was stronger. I prepped the surfaces by rough sanding (prob 80 grit) and acetone wash. The 3M beat the other epoxies, I remember. I recall that I had to damn near chisel the pieces apart. Epoxy does lose strength with temperature - same as epoxy resin in a fiberglass hull. at 160 deg. F (easy to get on a dark surface in the sun) I think epoxy has about 1/3 or 1/2 it's strength -don't remember for certain off hand, but it is really substantial loss. I remember this from composite aircraft construction - that's why composite airplanes are usually painted white, and a good reason to have a white fiberglass boat. Of course boats can be water cooled - but the top deck isn't unless you crash thru some waves.... just my rambling thoughts...
__________________ Wherever you go, there you are... |
| Oh, the 3M epoxy was an industrial product. 3M makes dozens of different epoxies.
| Here's a interesting article on the Lotus Elise's chassis. http://www.sandsmuseum.com/cars/elis...al/asauto.html |
| 14 gauge or thinner material it's best to rivet, 12 gauge or thicker, weld. My Kestrel design for an aluminum ketch used 12 gauge for this reason. |
| Aluminum build with RIVETS? | FAST FRED | Metal Boat Building | 19 | 11-30-2007 05:54 AM |
| Box Rivets | cac | Boatbuilding | 0 | 12-04-2006 08:57 PM |
| rivets or screws? | muskieslime | Boatbuilding | 10 | 08-11-2006 12:47 AM |
| Broken welds | BWBasser | Metal Boat Building | 9 | 05-25-2005 12:04 AM |
| removing rivets | nighthawk | Boat Design | 2 | 04-19-2005 09:17 AM |
