For myself, I'm overcoating clean primed plate or plate wiped down with methylated spirits. For some reason I don't understand, bare steel doesn't seem to rust in my shed. PDW |
If you look at the powder rust that blooms on a fresh steel surface it's very poorly adhered globular specks which does absolutely nothing to promote paint adhesion and can be wiped off with a cloth. I have seen steel weathered to remove millscale then wire brushed and painted with epoxy and it worked very well but that's new steel. But if you sand blast as asked about above then you have your ideal key and the paint manufacturers will stand behind you. Maybe ![]()
I find that blasting puts a much better 'tooth' on the steel than grinding does whether using a flap wheel or hard grinding wheel. However it's a terrible job. I used to think I hated angle grinders before I discovered sand blasters. When one compares the 2, I find that I merely dislike angle grinders. The bright side is, I've almost finished. Anyway, my observation is that the Jotun 605 epoxy paint is tough as hell and binds rust so works well on imperfectly cleaned surfaces. It is obviously going to work better on a properly prepared surface. PDW |
| How to build a steel barge | Big Builder | Metal Boat Building | 26 | 03-15-2012 12:30 PM |
| How to determine the frame spacing for deck cargo barge using ABS Steel barge rule? | jimianbu | Class Societies | 8 | 11-22-2010 07:40 PM |
| Looking for small steel barge plans | BARGEASE | Metal Boat Building | 8 | 09-03-2009 12:08 PM |
| Steel Barge again | continentshift | Open Discussion: All Things Boats & Boating | 11 | 01-01-2009 01:47 PM |
| foam filler for steel barge | Sue Fox | Metal Boat Building | 5 | 11-29-2004 07:18 PM |
