| replating steel hull? I have never worked metal. Refitted two fbg boats (only an 18 foot and 24 foot). I make no pretense as a boat builder. Backyard type experience only. Found a freshwater 14x42' single hull houseboat. Hull date - 1964. Asking $20M. Can steel last this long? Have heard steel oxidizes from the inside. (true?) Would a boat yard even want the work these days? How much $ would a replate cost me? Some advice and links is all I am really requesting. I like the old stump knocker and would retire to it. Regards, |
| Properly maintained, steel can last pretty much forever. Is there a lot of corrosion on the hull? Plate thickness can be checked with non-destructive methods and will tell you how much steel is remaining, but I don't think re-plating is the way to go. If the steel is good, wire brush it and paint it and if it's not, don't buy the boat. |
| How much is $20M? Last edited by Poida : 04-05-2011 at 08:14 PM. Reason: Wrong figure |
| Probably $20,000 USD. I've seen the M = $1000 convention before, but not often. |
| Have heard steel oxidizes from the inside. (true?) Yes indeed...to inspect a steel hull get a bright flashlight and look in the bilges , stem, stern and sheer clamp. . If you see any scale corrosion on the inside of the steel hull skin ....walk away. steel is cheap and easy to work with...cutting the inside furniture and systems away to gain access to the hull skin to repair the steel cost a FORTUNE. |
| Get a surveyor that can use a metal thickness tester.
__________________ Gonzo |
| Perhaps...but for a small craft its an expensive procedure that is not particularly accurate. Ive had a rust bucket steel hull tested and passed, even thou the anchor chain locker stem and plating at waterline level was known to be rotten. Hull plate sounding are best for double skin vessels in which inner skin examination is not possible. Best to physically examine...your eye don't lie. If you see something ...call in a surveyor for a second look. Im involved with a rudder skeg repair on a metal boat now. A surveyors thickness sounding would not have exposed the corrosion.....only when the bearing shoe was removed did it become visible. The metal work will be cheap and fast to rebuild...the amount of destructive disassembly to gain access to the stern peak will be expensive to rebuild |
| Thanks A surveyor? Do they mess with craft this small? If the boat is still for sale next month, I will inspect as you guys suggest. Thanks for the timely replies, gentlemen. Regards |
| I do, and there are many others that will also.
| Replating Questions | Dave Patterson | Metal Boat Building | 12 | 07-15-2010 01:35 AM |
| more replating questions | Dave Patterson | Metal Boat Building | 3 | 07-13-2010 10:27 PM |
| Welding a steel hull | Wynand N | Metal Boat Building | 329 | 09-04-2009 04:22 PM |
| small steel hull | guest | Metal Boat Building | 4 | 09-03-2004 01:29 PM |
| steel hull repair | minstrel | Metal Boat Building | 4 | 09-03-2004 12:46 AM |
