| Replating Questions I have a 28' steel work boat that needs to have plating replaced. The boat is in very good shape except for the steel approx. 30" on either side of the keel and running the length of the boat. I do not weld but will be enrolling in a night school class at a nearby community college. I have been reading everything I can get my hands on to try and get myself up to speed on construction techniques. This website has been great as well as a number of books recommended by other members! I would like to start removing the old plating and am looking for some advice. I don't have a torch or a plasma cutter nor would I feel comfortable using one. Can I use a reciprocating saw to cut the old hull plating as close to the longitudinals and the frames as I can and remove the steel in small sections? I thought I could then use a grinder to remove any remaining material. Is this a good plan or can someone suggest a better approach? Also, I will need a welder. I've been thinking about purchasing either a Hobart Stickmate ac/dc or the equivalent Lincoln. From what I am reading, the dc capability is a plus when welding thinner materials. I will be doing all work outdoors so a mig seems like a poor choice. Any suggestions? Thanks |
| Unplug when it rains?
| Seriously, build a little welder's cart so that you can move it indoors during inclement weather. Shipbuilders have been welding outdoors since the beginning of modern times.
| By 'working outdoors' I was referring to wind and shielding gas and not my inability to move a welder into my shop 30' away. Seriously |
| Sorry about that. I have found that reciprocating saws are more uncomfortable after extended periods of cutting. Have you any inclination to put a metal cutting blade in a circular saw? Pre-drill alignment holes from backside and mark saw side with crayon or chalk. Straight lines only, of course. Just a thought.
| I see no advantage in avoiding the torch or plasma cutter. Cutting by saw or disc, is more cost and effort and the induced heat can be the same. Regards Richard |
| Dave, Have a look into using a 7" or 9" angle grinder with 1mm thick cutting discs. It could save you alot of dosh. Cheers Berty |
| Go over to any of the marinas on the Mississippi that have houseboats and ask them who does replating and then get advice from them. Most of the older boats are steel and it's a fairly common thing to have to have done. You might even want to get estimates. Unless you have help and equipment/tools, it's heavy stuff to maneuver around, especially overhead. And then you have overhead welding which is very much not the easiest. Most of the people who do it will be portable, as in generator/welder on a truck with tools, a lot of them will be one person operations. Maybe you can work something out with being their "help", getting materials, flexible schedule maybe, as in not in a gigantic marina spring rush hurry. No matter what, you'll find out how people go about it, where to get materials and other advice. |
| Welding Outdoors Welding outdoors is OK but don't do it on a windy day. If it it is too windy the breeze will blow away your sheilding gas and you will end up with porosity in the weld. Another option is to use flux core MIG wire. Scott Fab Manager Welders360 |
| A MiG with flux wire works fine outdoors regardless of wind. You can fill gaps much easier, specially if you are just learning to weld. There is less likelihood of burnig through and making holes in the plating too.
__________________ Gonzo |
Mike |
Then, if you are a stickler for QA...dye-pen the root before you seal outside. |
I usually back gouge from the outside with an angle grinder until the blade shows solid steel and then laid down the filler/cap run. Then again, I had built 90% of all my boats upside down which makes the back grinding much easier (safer) and most outside welds in a down hand condition.
| Olds 455 questions upon questions... | pdswerld | Gas Engines | 26 | 07-07-2010 09:36 AM |
| Questions | dmille5 | Outboards | 1 | 10-17-2009 11:42 PM |
| a few questions | ironmatar | Sailboats | 17 | 03-19-2008 12:05 AM |
| Various Questions | KI4NCW | Metal Boat Building | 30 | 02-02-2007 06:30 PM |
| Some questions. | fcfc | Option One | 10 | 11-05-2006 04:39 PM |
