Old 04-18-2010, 08:37 PM
Cheapshot Cheapshot is offline
Rep: 10 Posts: 11
Replacement Rivets
I have been scouring the internet for replacement rivets for my 1973 12 foot Ouachita aluminum boat. I found a source that describes the type needed as a Closed End Rivet. Does anyone know off the top of their head what size (i.e., Diameter, Length, Head style) would be needed for my particular application?
Secondly, How does one flatten the narrow end of the rivet once installed?
Old 04-19-2010, 02:27 AM
Rep: 1758 Posts: 1,561
"Closed End Rivet"?
I doubt a "pop" rivet was used in intial production. A "closed end rivet" is a hollow blind rivet where the expander is forced into the barrel and seals any leak path when it breaks off. But I doubt they were used in major seam production of a commericial hull, especially if you ask for a method to "flatten the narrow end of the rivet once installed"
This is a "closed end" blind (worked from only one side) rivet
This is a common production (tublar) rivet.
Aluminum Rivets silverslayer Materials 7 02-17-2008 12:37 PM
Aluminum build with RIVETS? FAST FRED Metal Boat Building 19 11-30-2007 05:54 AM
Box Rivets cac Boatbuilding 0 12-04-2006 08:57 PM
rivets or screws? muskieslime Boatbuilding 10 08-11-2006 12:47 AM
removing rivets nighthawk Boat Design 2 04-19-2005 09:17 AM
