Old 09-15-2006, 10:19 PM
simon simon is offline
Rep: 70 Posts: 101
Reinforcing alu chainplates
The force of the stays is starting to wear the holes on the chainplates. What are the solutions to prevent stainless bolts to pull through the soft aluminium? Is there any standard way that is used in aluminium boatbuilding. On boatbuilder told me that he glues stainless steell tubing with Araldite into the holes.
Thanks
Simon
Old 09-16-2006, 03:49 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
A steel tuubing set in epoxy sounds like a good solution.
Some nylon fittings may also work.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 09-16-2006, 07:49 PM
Rep: 1623 Posts: 2,344
Esspecially on larger boats the chain plates should have sleeve inserts. Often just turned from 316 and press fitted. Ensure there is enough of the chain plate remaining for the larger hole required to take the insert.
Mike Johns.
Old 09-24-2006, 12:18 AM
Rep: 70 Posts: 101
Thanks for your responses, I will be going for the stainless steel inserts.
Simon
Composite chainplates tbot Fiberglass and Composite Boat Building 15 08-07-2008 09:45 PM
Reinforcing Inflatables dirteemonkee Projects & Proposals 3 06-20-2006 12:32 PM
chainplates Lunde Wooden Boat Building and Restoration 0 10-08-2005 02:02 PM
REINFORCING a STERN Branko Boatbuilding 0 07-02-2004 07:24 AM
reinforcing oars dgu56 Boatbuilding 0 04-18-2002 12:15 AM
