Old 05-03-2010, 07:41 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
Well, you are not actually protecting them unless they are connected with a cable to your hull, but they certainly create a few millivolts and these keep nibbling at your anodes until there is nothing left.
If the hull has no aluminum parts in the water you could use Al anodes and save a few $$, but zinc protects better because the voltage potential is higher. The conductivity of the water also plays a role.
Old 05-03-2010, 08:41 AM
apex1
Originally Posted by wildman View Post
The second thing was that on haul out I found most of my anodes corroded more or less equally except for two both on the stbd side. Two mounted in a similar location but on the port side were in need of replacing. These two were the same make/size as the stbd side two. The port side lies along side an unpowered dock while the stbd is some 6 metres from the next dock. The dock is held up by rusting steel pylons - am I protecting the landlord's (docklord's??) pylons?
There is something positive in this case! You have the proof they work correctly, sacrificing themselves!
Well said Cornelis!
Regards
Richard
Old 05-03-2010, 09:12 AM
CDK's Avatar
CDK CDK is offline
retired engineer
A quick addendum because I was distracted and didn't finish the reasoning.
Taking stainless steel as a reference, the potential between ss and aluminum is approx. -.2 Volts, zinc gives over -1 Volt, so it is much more active. To obtain the same level of protection you would need 5 times the number or size Al electrodes, so cheap turns out to be expensive!
In clean, low conductivity water you could use Al because corrosion rate is low, in distilled water you need nothing at all.
Thanks Richard. I'll try not to get overconfident.
Old 05-03-2010, 10:51 AM
mark775
Up here, one used to be able to find aluminum everywhere for free (scrap) and it made sense. They are both expensive now ($1 lb.) but two savings are that, if you can get zinc without too much shipping cost, it will be far cheaper than buying zincs (Alaska/Hawaii, etc., more so), and people throw out slightly used zincs all the time.
Old 05-03-2010, 05:08 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
A little more caveat on zinc smelter: http://chestjournal.chestpubs.org/co...3/862.full.pdf
Hoyt
Old 05-03-2010, 05:38 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
..stick with the zincs, you already have them anyhow....
Old 05-08-2010, 07:24 PM
LyndonJ LyndonJ is offline
Rep: 233 Posts: 302
There's some good reading here too
blisters around zincs on steel boat
Old 05-08-2010, 07:50 PM
mark775
Wow, Hoyt - ought not breath it!
Anodes dick Boatbuilding 2 08-21-2009 06:35 AM
which zinc to use mudmanjw Boatbuilding 0 11-01-2008 12:45 PM
Anodes sailrjim Metal Boat Building 9 12-04-2005 04:48 PM
Will I need a zinc anode? Matthew Boat Design 3 08-25-2004 07:56 AM
sailboat recycling rickc Powerboats 10 11-19-2003 11:34 PM
