| rail cap and beltings Dies cut and samples done scale-- the belting face is 16mm, alloy 6082 T6, Anybody can use, i can add to order any length to 10m Last edited by Guest62110524 : 06-21-2010 at 05:30 AM. |
| Hi Whoosh, Looks like there's plenty of "goodness" in that belting/sponson. all the best with it from Jeff. |
I think I will router that in for use on the fresh water , as some of the locks have concrete breastworks etc andf the al does get scratched, it is there as a rubbing belting, not for looks render by bhnautika from the forums Last edited by Guest62110524 : 06-21-2010 at 05:29 AM. |
| The rail cap, I understand. What is the horizontal dimension and how much does the cap weigh? Can this alloy be annealed and bent? Welded? How does the belting fit where on a boat? |
the other just above wl, because many locks put the boat way up high Both sections can be pressed, although the belting with go around without for the cap I draw the plan of it and press in a horizontal press, hitting every 6 inches or so enough to move it, it should be a close fit, because you wont pull it around without forming You dont need soften(anneal ) it the weight is 4.67 kg/m for belting and 4.56 kg/m for caprail when pressing I use hardwood to protect the edge go to faces to names thread you can see my last yacht with the caprail on |
| Looking for Deep cycle high cap batteries AGM or Gel in stock | ekraus | Materials | 0 | 08-16-2008 01:38 PM |
| Shorten a fiberglass truck cap | imagineer | Fiberglass and Composite Boat Building | 8 | 07-30-2008 07:43 PM |
| Oversize beltings | CTMD | Materials | 0 | 05-25-2008 07:49 PM |
| Design student removing cap from hull. Where to cut??? | phi784 | Fiberglass and Composite Boat Building | 11 | 08-08-2007 11:18 PM |
| HEI Distributor - Coil on Cap | jgalt_Winner-28 | DIY Marinizing | 1 | 11-17-2006 06:52 PM |
