Old 08-03-2008, 03:50 PM
greenwater greenwater is offline
Rep: 10 Posts: 4
radius chine == radius bilge ?
Hey all,
I've been looking at a few different designs for many years and think it's almost time to start building.
My question is about a Ted Brewer design that I really like, the Orca 45'. The website says it's a radius bilge type hull. I've been comparing this to some Bruce Roberts designs which have radius chine hulls which are suppose to be much easier to build than a round bilge (Bruce differentiates these in his books). Yet even Ted seems to make a difference between his radius bilge and a true round bilge. Are these two processes just different names for the same construction process from each designer? Will a standard metal shop be able to provide me w/ radius bilge pieces?
Does anyone have experience building a radius bilge from Ted's designs? Is radius bilge same as radius chine? I'm wondering how much of a difference this is from the radius chines which I think I find quite easy from reading Bruces books and how much the steel process changes.
Old 08-04-2008, 12:16 AM
Rep: 2891 Posts: 8,792
Yep, just two different terms describing the same thing. Both are developed, flat panel builds, but have a rounded over chine areas. This is also known as a "soft chine" type as well.
Old 08-04-2008, 12:35 AM
Previous Member
Rep: 0 Posts: 0
and in my opinion they are neither fish nor fowl, they look horrible, a serious compremise
Old 08-04-2008, 12:58 AM
JeroenW JeroenW is offline
Rep: 30 Posts: 40
But besides the looks, are there any other reasons to not use this technique?
Old 08-04-2008, 05:21 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1544 Posts: 1,138
I beg to differ from you Jack If designed by a designer that knows his stuff, it is just as pleasing to look at as any other boat...
A little tale that happens to be true as told to me by Dudley Dix; In the early 90's, a very well known designer (now residing in NZ) and the doyen of SA designers at the time, looked at one of Dix's radius chine hulls on the dry about to be launched, and made the remark that it is one of the best round bilge steel hulls he has ever seen. Was he flabbergasted to learn that it is in fact a radius chine hull.
Yes, I had seen some less than nice radius chine hulls in my time and the Robert's version comes to mind. Some American designers also make them look sad and this is mainly due using different radius along the hull...
A round bilge is not a radius chine. Most fibreglass hulls are round bilge designs as you have ever changing curves all over the hull so to speak which makes it difficult to duplicate in steel unless you are a very skilled steel worker.
Radius chine hulls are actually a single hard chine hull with the chine "softened" as pointed out by Par. As said before, if it is properly designed, it CAN be more pleasing to look and at as a proper round bilge hull...in fact, without being biased, I think it looks better overall.
And the beauty of this type of construction is that it is well within the ability of amateur builder and actually very easy to build
Just to put your mind at ease regarding the "looks", I attach a few photos of Dix designed radius chine hulls. Three photos are of the Dix43 now under construction at my shop and as a matter of fact, one of Dix earlier - 1987 - designs and his later ones are much more pleasing if I may say so.
The other two are of a Dix65, designed in 1990/1. I had build the Dix38 (which I actually commissioned in 1991) and the Dix57 and both are just as nice.
As for the looks, study the pics and you be the judge...
radius chine == radius bilge ?-waratah-001.jpg  radius chine == radius bilge ?-waratah-003.jpg  radius chine == radius bilge ?-waratah-004.jpg
radius chine == radius bilge ?-f1000022.jpg  radius chine == radius bilge ?-f1000064.jpg
Wynand
A scatterling of Africa
Old 08-04-2008, 05:52 AM
Wynand is correct, especially in modern hull forms. Well designed soft chine designs look quite good and most amateurs would be hard pressed to tell the difference from round bilge.
Old 08-04-2008, 03:04 PM
Rep: 30 Posts: 40
Wynand, I am following that Dix43 project of yours with admiration.
Thanks for clarifying.
I assume that strength wise, a well designed radius chine hull is not inferior to a (multi) chine or round bilge hull?
Old 08-04-2008, 10:16 PM
Curved panels are always stronger then flat ones.
Old 10-24-2010, 03:54 AM
tugboat tugboat is offline
insert cheesy line here
Rep: 56 Posts: 548
i am building a John G Alden tugboat Circa plans from around 1952. when i look at the hull form(i have a model) It looks like a round bilge to me- there is only on section that would be a compound curvature. the bottom appears to imitate a chine hull but there is no chine. the bottom is slighlty vee'd. and the sides plumb(for towing on the hip. would this be classifed as a round bilge?http://www.boatnerd.com/pictures/tug...ndianab-th.jpg
http://www.tug44.org/tugboats.trawlers/tug-8th-sea/
the "Empiricist" school of boat design
Old 12-14-2010, 05:00 PM
viking north viking north is online now
Rep: 676 Posts: 1,067
Well designed double chine construction hulls are certainly not ugly and there might actually be a little spinoff. There is an ongoing study and debate that a properly designed chine hull in certain situations might actually be faster than her non chined sister.The theory being that the chine ridge actually creates lift resulting in less wetted surface and possibily a little gain to winward ability. Anyhow food for debate. Geo.
Radius Chine Hulls Inerested Boat Design 7 02-12-2008 08:04 AM
Steel-made hull with fiberglass-made radius chine ? xarax Metal Boat Building 48 07-23-2007 12:35 PM
Steel-made hull with fiberglass-made radius chine ? xarax Boat Design 0 07-05-2007 02:43 PM
Radius of strake and chine jfblouin Boat Design 0 10-13-2005 11:33 AM
Dix Radius Chine Designs bjl_sailor Boat Design 11 06-15-2004 10:26 AM
