Old 04-10-2007, 06:03 PM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 278 Posts: 581
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
Originally Posted by alan white View Post
I worked out a V drive that used no gears (1:1 ratio) a few years ago.
I'd like to see that. My current boat (in USA) has a Casale V Drive with a (Shaft I always called "The Drive Shaft") made from a Chevy drive shaft, with universal joints at each end.. It's about 40 inches long, I think. But how did you "change direction"?? No gears.. Hmmm. Chain/Belt??
Regards, Terry King ...On the Red Sea at KAUST
Old 04-10-2007, 06:41 PM
Capt Sport Capt Sport is offline
Rep: 12 Posts: 8
Ok, to clear up the mystery of where I got the term jackshaft, which to my knowledge has been around in the boating industry for well ever. You can follow the links below.
http://www.albemarleboats.com/traile...fications.html
http://www.volvo.com/vce/Templates/G...ACHEHINT=Guest
http://marine.cummins.com/public_cum...Id=13&menuId=1
So, you can see some pretty big players in the marine industry use the term as well.
Thanks for your replys!
Cya,
jr
Old 04-10-2007, 06:46 PM
Rep: 12 Posts: 8
Driveshaft vs Jackshaft
Originally Posted by Rusty Bucket View Post
I know the term "jackshaft" and I thought it already had a home. If that's a jack shaft then what's a drive shaft? I think the terminology is confusing at best. regards rusty
Rusty,
Driveshafts are what are in your truck, 4x4's have 2. Jackshafts are what there called when in a boat. Essentially they do the same thing in different platforms.
Cya,
jr
Old 04-10-2007, 07:34 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
It's based on a link at the juncture that has four bearings at ninety degrees to each other, like a u-joint. The inspiration came from a very old patent for an L-shaped link to turn a shaft around a corner without gears. I've got the drawings for the V-drive somewhere. I'll upload them when I learn how to use my new camera.
The concept of using bearings for gear reduction has always fascinated me. Most are called trochoidal drives. I designed a 5 speed sailboat winch a few years ago, got Harken interested enough to consider it, but no cigar.
That had a bottom (reciprocating) handle for four ratios and a top crank for fast 1:1.
It incorporated a rotating cam that shifted by twisting the handle. It had three moving parts. The efficiency I figured would be about 98-99%, contrast to regular winches at 85-90%. I've got hundreds of drawings of that one.
Trochoidal drives are probably used on submarines to reduce the turbines speed. They have zero pitchline velocity error, something that causes cut gear teeth to make noise (a micro-chatter that comes from an ever so slight speeding up and slowing down of the driven element due to imperfect polishing or wear. True of all gear drives, but averaged in helical cut gears, trading smoothness for frictional loss).
Subs gotta be real quiet. One drive I came up with showed up already patented in a search. In 1985 someone had sold it to the US Navy. It was identical to mine.
I do it for fun now. Too much bother trying to patent something people expect to come from an engineer. Very hard to get an audience as a non-professional.
Alan
Old 04-10-2007, 08:49 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
I always refer to it as a drive shaft too.( A shaft that drives)
A jack shaft is probably some American terminology that we have now and its just another word in the English language we just have to go along with.
Same --wrist pin --gudgeon pin
lifter --cam follower
Transmission ---tranny
gear shift----gear lever
Bonnet ---hood
boot ---trunk -----and it goes on
Old 04-10-2007, 10:32 PM
rayk's Avatar
rayk rayk is offline
Rep: 146 Posts: 297
I think you are right jack frost.
Jack shafts normally have cogs/gears/pulleys on them, except on American boats.
Snow mobiles, karts, diesel locomotives, motor bikes and mechanical engineers all illustrate a jack shaft as being geared and in parallel to its input and output.
Below, the jack shaft is part of the reduction gear, not a flange bolted shaft.
The illustration below is from NASA, so being wrong aint bad company.
Old 04-10-2007, 10:49 PM
Frosty's Avatar
Input shaft -output shaft -1st motion shaft, layshaft , centre shaft, gear cluster shaft, transfer shaft, PTO shaft, propeller shaft
Normaly a shaft is described in the word preceding it--ie reverse gear idler shaft,---pretty descrptive? jack shaft? --not very clear.
Shaft fitted by Jack??? jack **** shaft-- does nothing?
Old 04-10-2007, 11:14 PM
Rep: 12 Posts: 8
Wow, who’d of thought a simple question would cause so much controversy. What’s funny is that “jack shaft” is an accepted term in use by Cummins, Volvo and Mercury marine just to name a few. Which are undoubtedly major players in the marine industry worldwide. Yet so many people here on the boat design board seem to have never heard it.
Oh, since you seem so adamant about the fact that you’ve never heard the term, so it must be more made up American B.S. Just maybe you Mr. Frost, define the term “jack ****” as in your knowledge or lack there of. As apposed to being open to learning something one doesn’t know.
Cya,
jr
Old 04-10-2007, 11:28 PM
Willallison's Avatar
Rep: 2280 Posts: 3,467
now now gents, lets not let this get personal
It's not a case of being a US term - it's used throughout the marine industry as a description of the set-up as shown earlier by Bob S. It's a perfectly straight forward setup and is very common.
Will
Imaginocean Yacht Design
www.imaginocean.net
  #25
Old 04-10-2007, 11:57 PM
alan white's Avatar
It's a troublesome term.
A.
  #26
Old 04-11-2007, 12:00 AM
alan white's Avatar
Bonnet ---hood
And that British term for the thing that spins between the tranny and the differential on rear wheel drive cars...?
  #27
Old 04-11-2007, 01:32 AM
Frosty's Avatar
Oh, since you seem so adamant about the fact that you’ve never heard the term, so it must be more made up American B.S. Just maybe you Mr. Frost, define the term “jack shit” as in your knowledge or lack there of. As apposed to being open to learning something one doesn’t know.
Cya,
jr
Dear oh dear,- only 7 posts and into insulting outbursts. Im sorry that you dont like my interpretation of a jack shaft---you asked the question.
You may remember your first attempt at posting a thread met with similar confusion.
I was suggesting that shafts generally have a name preceding---Oh well you can read.
Myself and other members were now discusing why perhaps a jack shaft is so called. Not that it did not exist. This has obviously angered you because you are not getting what you expect from members who try to diplomatically help you,-- and I hasten to add for free.
As this is not enough ,--part B of you question is equally as confusing how does this affect manouvarability???????????????
The same way as moving the engine would!!!
You seem to have poor understanding of engineering terminology. Your question are confusing. If you dont know what it is, just say the thing that drives the!!! we will understand,-- rather than googling it and asking incorrectly.
Trying to talk engineer to an engineer will aways catch you out.
  #28
Old 04-11-2007, 12:52 PM
Rep: 12 Posts: 8
Thanks to all that replyed, I sincerely appreciate the information.
Cya,
jr
  #29
Old 04-13-2007, 08:07 PM
dsharp dsharp is offline
Rep: 10 Posts: 12
jack - shaft
I knew exactly what you were talking about. I have a 23' Seacraft that was originally set up with a volvo i/o and a 4 cyl diesel mounted midship. I took it out and converted to straight inboard. I never liked working on i/o's after they have been in saltwater. On boats the size that you are talking about I don't know that the handling would be much different because fuel tank placement usually is going to be aft or mid depending on engine placement and the weights are similar.
  #30
Old 04-29-2007, 03:49 PM
BillyDoc BillyDoc is offline
Rep: 266 Posts: 421
Alan
Alan, you really have me curious about this, especially the "L" drive and your "V" drive . . . did you get your camera working? I would love it if you posted some details on these various concepts.
Thanks!
BillyDoc
Jackshaft pros and cons Capt Sport Boat Design 2 03-31-2007 05:40 AM
Stepped hulls pros and cons AdrianRO Powerboats 8 11-24-2006 07:43 AM
Pros and Cons of an I/O system shadowrack Powerboats 5 02-17-2006 09:11 PM
Pros and Cons of Transom Hung Rudders Gone Ballistic Sailboats 19 09-19-2005 09:15 PM
Inflatables, pros & cons? Splint Open Discussion: All Things Boats & Boating 20 05-16-2005 02:54 PM
