Old 11-22-2009, 08:46 AM
Kiev Fernandes Kiev Fernandes is offline
Rep: 10 Posts: 23
prob with gullco gbm-18 beveling machine
while beveling, the machine pushes the plate out. it bevels only 20 or so mm and then the plate slides out of the teeth.
NE SOLUTIONS
Old 11-25-2009, 08:07 PM
welder/fitter's Avatar
welder/fitter welder/fitter is offline
Rep: 164 Posts: 154
gullco gbm-18
A photo would help. Am I right in assuming that you have the gbm-18 floor or table mounted? And, you are feeding the material? I prefer the "bug" bevellers, like the gullco kat, great for out-of-position (in the field) cuts/bevels. I don't have time to read the specs/brochure. Does this unit have feeder rolls? I watched the video and know that I wouldn't be happy with a beveller rolling along the floor with no track to control it. I'd suggest you create a track, so the beveller cannot move away from plate.
Best of luck!
Mike
Old 11-28-2009, 06:18 AM
Rep: 10 Posts: 23
thanks we solved the prob some settings were not proper.
Thermostat Prob On O/b LEASEGUY Boat Design 0 04-30-2008 01:50 PM
Thermostat Prob Ob O/b LEASEGUY Boat Design 0 04-30-2008 01:49 PM
rochester carb prob saabster Gas Engines 2 04-09-2007 12:17 PM
rochester carb prob saabster Inboards 3 04-08-2007 11:23 AM
Duncanson 28' Racer(GBM) specifications? markjaffa Sailboats 1 03-06-2006 12:11 AM
