| plating, how not to saw this abomination in France Strangely IT was built in Holland, imagine the welding. It is the only boat In have ever seen plated vertically in strips I also got to use this state of the art machine in Poland last week |
| I've seen other steel vessels here in Asia with vertical strips at the bow. Especially iwo of bow thrusters, not a pretty sight. However, if the butts are well supported at both ends and there isn't a long.t strength issue, nor triaxial stress raisers, it "should" be ok. It does allow those with less skill to plate more complex curves. |
| Is it just me, or does it look like the shell has been plated over? An original welded shell should never have relief like that no matter who did it.
__________________ The only thing a Naval Architect has to sell is his opinion. |
| I kinda like it more than most boats i see |
| Yes, odd....i saw the rubbing strake, but didn't see the odd looking shape of plate that appears to be either a thick insert (but no taper) or a bloody large doubler over the hawse pipe!..odd! |
__________________ Fair Winds Wynand Nortje http://www.steelboatbuilder.com/ There are no problems, only solutions - John Lennon; 1940 - 1980 |
| Oh my gawd i only figured out now that the second pic is a welding machine jeez talk about suicide kids - wow sorry a bit slow this morning - too much epoxy yesterday ![]()
__________________ Bye bye Folks - off to see the world he he======================================== Compulsive Neurotic Manic Depressive, but basically happy :) http://compaxboats.wordpress.com/ http://www.boatdesign.net/forums/boa...ser-27869.html |
| Manie, that gives a new meaning to a buzz box welder... I wonder if Stuart can enlighten me if the woman still have chest hair in Poland ![]()
| i think its macho, a "the hell with what you think" look it looks like it came off the liberty ship line probably has a single cylinder chug a lug diesel, 2 cylinders at most |
| It looks like a wooden boat "steeled over". There are many like that in the Great Lakes
__________________ Gonzo |
| No , I think the bottom vert. pl was just lapped over the top (run) here is a useful link for SMAW welder shttp://www.millerwelds.com/pdf/guidelines_smaw.pdf Although I spose it could have been overplated, never looked closely Polish woman? some exceptionally beautiful ones , have to face the fact, that,at my age I am invisable to them )The welder, well my friends father(from this site) has had it by him for 60 years Dunno if was the machine or the rod, but it ran like very long interval pulse with arc stopping and starting Needless say without my glasses the weld looked like something spattered from aloft boat 40 tonne the crane was magnificent computerised state art 10000euros to lift in , they loaded 50 tonne weights to the centre of the crane It is a 200 tonne caqpacity machine |
| In the last picture, you can clearly see that the stem is rivited. So my opinion is that someone plated over an original furnace plate rivited hull. The "orange peel" sections are needed because you can never roll a plate to match a furnace plate. With the picture of the hull, it looks like pre-war canal boat, so standardized mass construction would not make a furnace plate hull unreasonable.
the drama after the launch was something else, would youi like a large file vs of pic? Not sure what your term furnace pl means Boiler plate? Have seen some beautiful fully riveted ships, some of which, the plate lines were perfect I think the Germans had the lasst of the riveted ships That 32mm stem bar was needed hours later as she ploughed into rocks, when the astern gear failed |
A lot of the late German work was actualy composite riveted and welded, with the butts welded, but the seam riveted. The USCGC Eagle (ex Horst Wessel) and her sisters are of this construction.
| Custom Chrome Plating | Chromeplater | Open Discussion | 0 | 06-11-2009 08:58 AM |
| Plating over a steel hull | ljw | Metal Boat Building | 10 | 06-20-2008 08:03 PM |
| effective plating | eduard | Class Societies | 6 | 11-13-2007 04:42 AM |
| plating, aim for this | lazeyjack | Metal Boat Building | 4 | 07-22-2007 07:12 PM |
| plating thickness? | rlackey | Boat Design | 31 | 07-17-2005 06:18 PM |
