Old 06-27-2009, 07:36 AM
Rep: 529 Posts: 1,599
I think this technique of bow plating was in vogue for a while.
Mike Johns.
Old 06-27-2009, 04:30 PM
whoosh's Avatar
whoosh whoosh is offline
boatbuilder
Rep: 309 Posts: 582
tee hee, I once started a thread, Bueautiful Metal Boats, perhaps we should start The Ugliest Metal Boats, most would come from Australia
Although that one has a nice enough entry albeit a wet ride in stiff bzeeze
Old 07-03-2009, 05:36 AM
JeroenW JeroenW is offline
Rep: 30 Posts: 40
Defiance -> What's in a name ...
Knowledge is like a circle, the bigger the surface the longer the edge to what we don't know...
Old 07-03-2009, 09:12 AM
wardd wardd is offline
Rep: 132 Posts: 250
it floats it cant be all bad but then i think liberty ships were beautiful
Old 07-03-2009, 07:15 PM
Rep: 99 Posts: 491
Vertical plating can create a huge increase in drag if it is not totally fair, as the water flows across the seams, rather than along them.
A friend did an electronics job behind the iron curtain in the communist era. Some of the most beautiful women imaginable there made a beeline to the westerners and dropped their local boyfriends, as they saw a way out. Many of this crew came home with new brides.They obviously thought to so too.
White South African women are so useless that they don't know how to boil a pot of water without burning it.
Brent
Old 07-22-2009, 06:13 AM
Brent
In reality the drag is not that great, it will stimulate tubulent flow a little earlier on but it will make little difference with a long low aspect keel. Sometimes early turbulence prevents laminar separation and vorticity. With fluids it's never simple unfortunately unless you have high aspect foils, then you keep a nice attached flow across the foil and it had better be smooth and acurately manufactured to the design cross sectional shape too.
Mike Johns.
Custom Chrome Plating Chromeplater Open Discussion 0 06-11-2009 08:58 AM
Plating over a steel hull ljw Metal Boat Building 10 06-20-2008 08:03 PM
effective plating eduard Class Societies 6 11-13-2007 04:42 AM
plating, aim for this lazeyjack Metal Boat Building 4 07-22-2007 07:12 PM
plating thickness? rlackey Boat Design 31 07-17-2005 06:18 PM
