| pickled steel Discount Steel sells commercial grade hot rolled pickled and oiled 10 gauge steel sheet. Is pickled steel suitable for boat building and doesn't the process just remove the mill scale? Thanks, Dave Patterson |
| never used it. The oil can be a problem when it comes to painting.... My 2 cents worth
| Without sandblasting, you couldn't get anything to stick to it, which makes the pickling irrelevant. Working on it would be kinda greasy. |
| Thanks for the info. I'll stay away from it. Dave |
| Dont like to agree with the BS, but leave it. Get a A grade weld primered, wheel abraded steel instead. |
Apparently the oil comes off with a good detergent scrub. If you can get blasted & primed plate, do so because this is going to be the least hassle to use. If you can only get either hot rolled or pickled & oiled, take the pickled & oiled. It's going to be a lot less hassle, time & money getting the oil off than mill scale. PDW |
| Thanks pdwiley. Discount steel lists there hot rolled mild sheet a being lightly oiled too so I assumed this was the way steel is commonly sold. The pickling is just hydrochloric acid I believe. I haven't found wheel abraded or preprimed sheet in the Mpls. MN area. The pickled is priced the same as the hot rolled... approx. $140 for a 4'x9' sheet of 10 gauge. Any other opinions would be appreciated. Great website! Thanks again, Dave |
Most likely the oil will come off with a good detergent wash and if there's a VERY light rust-bloom afterwards, the 2 pack epoxy primers like Jotun Jotacote go over it without any problems. Better if there's nothing except clean steel of course. I'm using hot-rolled plate but every sheet is going through an industrial blasting & priming process before I weld it to the hull. It's expensive but a lot cheaper then blasting & priming the entire hull when finished. I couldn't get pre-primed steel or pickled & oiled steel anywhere. PDW |
| Steel Barge again | continentshift | Open Discussion: All Things Boats & Boating | 11 | 01-01-2009 01:47 PM |
| Free of charge, Steel - polyurethane foam -Steel insulation sheets | rossgiles | Fiberglass and Composite Boat Building | 0 | 03-18-2008 06:43 AM |
| Dix 43 in steel | StrandedMariner | Metal Boat Building | 4 | 09-28-2007 10:56 AM |
| Aluminium or Steel | Willallison | Materials | 2 | 07-27-2005 05:08 AM |
| Steel Cat | Fitcher | Metal Boat Building | 2 | 10-06-2004 12:36 PM |
