Old 01-08-2009, 07:15 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Heat causes distortion, take your time , dont just blast away and then look to see distortion do a bit at a time and keep some water handy.
1 inch one side,-- 1 inch the other. --patience.
Old 01-08-2009, 11:15 PM
Wittholz 35 Wittholz 35 is offline
Rep: 24 Posts: 12
Thanks Frosty. What is the water for? It seems like quenching it would cause it to warp more?
Old 01-09-2009, 01:18 AM
welder/fitter welder/fitter is offline
Rep: 423 Posts: 407
Originally Posted by Wittholz 35 View Post
...By the way what is a zip cut?...
Sean
A zip-cut is like a grinding disc, but thinner. It is designed to cut steel from it's edge. Don't try to grind with it. The cut is clean. For longer cuts, you can get a similar disc for a skilsaw.
Old 01-09-2009, 01:30 AM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
fitweld look to your pm, why are youa wake?
Old 01-09-2009, 04:31 PM
Rep: 24 Posts: 12
Ok so thats what a zip cut is. I was using those when my plasma cutter went down but I got it fixed now. I can cut a little cleaner with a zip cut but I use up wheels quick and besides the plasma cutter is a lot more fun.
Old 06-07-2009, 10:02 AM
lumpy bumpy lumpy bumpy is offline
Rep: -3 Posts: 37
Originally Posted by charmc View Post
Although it may sound daunting, sometimes replacing a larger area is actually easier than smaller patches. If Murielle is right that this is all toerail (it looks that way from your photos), then replacing a longer section would be best. Be careful to grind and/or cut back to clean, sound metal. Welding carefully should make it as good as new.
good advice
Stretching a steel hull Big H Buck Boat Design 3 01-15-2008 07:07 PM
Update on Patching an Aluminum Skiff Spud Boat Design 0 10-23-2007 05:49 PM
Patching a hole in aluminum Spud Boat Design 20 10-02-2007 09:56 PM
Steel hull repair Jason Crum Metal Boat Building 8 07-29-2006 12:34 PM
small steel hull guest Metal Boat Building 4 09-03-2004 01:29 PM
