Old 09-30-2006, 07:36 PM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
Opinions sought on best frame slotting methods.
Hello All,
How do those of you who have built, or are building a steel boat(s) slot your transverse frames for the stringers & chines?
The options I am aware of are the standard torch and a handgrinder with cutting wheel. Which is preferred.
Also, it would seem a plasma cutter might be a good choice? I have no experience with them but it seems logical that they may be well suited to the task.
Speed, accuracy, cleanness of cut, and heat generated are my list of variables.
I would be working with 1/4" mild steel stock.
Thanks.
TGoz
Old 10-01-2006, 05:08 AM
Rep: 1729 Posts: 2,462
Plasma if you have access. Make a profile and trace around it for each slot. Otherwise a cutting disk but those big grinders get heavy and the cut gets a bit sloppy..........accuracy is good for fairness overwelding a big gap is the distortion producer.
Check your frames after cutting as they tend to bow a little if flat bar.
Cheers
Mike Johns.
Old 10-01-2006, 10:42 AM
timgoz's Avatar
Thanks Mike. I figure to use an air grinder if I choose that method. Alot lighter than electric.
TGoz
Old 10-01-2006, 08:11 PM
Chapman Chapman is offline
Rep: 10 Posts: 7
Definitly plasma. To keep it neat and simple, I would recommend making jigs that match the cutout you want, but are wide enough to accomodate the width of your torch. Bolt heavy duty magnets to the back to hold them in place. This way, you stick the jig over the cut-out and simply run your plasma torch along the edge of the jig. Every slot should then be uniform. I can't imagine how your arms would feel after a day of cutting slots in 1/4" steel with a cutting wheel.
Old 10-01-2006, 08:36 PM
timgoz's Avatar
Thanks again.
All that cutting with a grinder would really pollute the in my face air too
TGoz
multihull frame nukem419 Boatbuilding 1 06-08-2006 02:06 AM
Attaching Flooring frame to Rib Frame. jeff goldberg Boat Design 0 05-24-2006 01:34 PM
Keel And Frame ? MACINAW Metal Boat Building 5 05-05-2005 12:20 AM
Input Sought: K 23 sport sailboat Billy Bones Boat Design 2 02-11-2005 11:23 AM
Boat Manual info sought FAST FRED Powerboats 2 02-10-2005 05:05 AM
