Old 07-21-2011, 02:03 PM
Timber wolf Timber wolf is offline
Rep: 10 Posts: 2
Originally Posted by ACuttle View Post
Do you have any photo's of this boat? I have a feeling I might have done some work on her a few year back - just the way you've descride things.
Hi there thanks for reply .The boat is small enough 27ft/9 beam the name on it or what I can see is york.
Paul.
Old 07-22-2011, 10:00 AM
ACuttle's Avatar
ACuttle ACuttle is offline
Marine Design Engineer
Rep: 40 Posts: 85
Paul.
Ah - a much smaller boat, than I thought. I wasn't aware there was that much with two props, in steel for that age of that kind of size. Live and learn. I'd be interested in seeing any photos still though - do you know what her purpose was?
-Drew
Old 12-04-2011, 11:24 AM
soapdodger soapdodger is offline
Rep: 10 Posts: 2
I think I've bought the boat you're talking about, same construction, size and name.
I'll be posting some pictures up, Ive started work on the boat and would be interested in finding some info on her history.
Old 12-06-2011, 05:02 AM
Rep: 10 Posts: 2
Here's a pic of the boat, I haven't anything on the internet simmilar and of the same age. Theres a tank on the boat stamped with: ENGINESPETROL I.R.P B.S.M Co 1940.
Its a small tank, maybe for the paraffin lights installed.
Old 02-20-2012, 08:21 PM
rayman rayman is offline
Rep: 50 Posts: 95
landlubber, what's the story on the "skode" I don't remember her, I was on the river at that time, (QCL) and where did she go?? regards ray
Old 03-18-2012, 08:46 AM
The Loftsman's Avatar
The Loftsman The Loftsman is offline
The Loftsman
Rep: 41 Posts: 57
Titanic
And so were many many other fine ships, all riveted, i find this quete pretty stupid
Originally Posted by Frosty View Post
Titanic was riveted --and built in Ireland, where is it now--just sayin.
"Fairline" A line that is pleasing to the eye!
www.leithshipyards.com
http://leithbuiltships.blogspot.co.uk
Old 03-18-2012, 08:48 AM
The Loftsman
Rep: 41 Posts: 57
Titanic
And so were many many other fine ships, all riveted, i find this post pretty stupid
Old 03-18-2012, 08:52 AM
The Loftsman
Rep: 41 Posts: 57
Riveted Hulls
Hi,
Depends a lot on whether the ship has spent her time in salt or fresh water, but a lot of old ships will be more than 50 years old and still retain 2/3rds of the original steel plate thickness
Some are more than 70 years old and still going, not many welded ships will get to this age.
Old 03-18-2012, 05:42 PM
Rep: 1729 Posts: 2,462
Originally Posted by The Loftsman View Post
Hi,
I think it depends chiefly on how well the coatings have been applied and maintained rather than whether it's used in seawater or not.
Leisure craft are usually subject to a considerably higher level of care than commercial vessels. Some old steel ocean cruising craft are pristine inside and out after many decades, and like any construction method will remain so unless they are poorly neglected.
Ships are built and maintained for a finite economic life and often allowed to corrode until finally rejected by class, then scrapped.
Mike Johns.
  #25
Old 03-18-2012, 05:53 PM
The Loftsman
Rep: 41 Posts: 57
Maintained
Hi Mike,
Agree a lot also depends on how well looked after.
  #26
Old 03-21-2012, 03:25 AM
FreeWill FreeWill is offline
Rep: 10 Posts: 4
I have a 100 year old riveted steel dutch barge and was told by the blokes in the yard (and the internet, so it's virtually true) that sand blasting could damage rivets. We had to scrape every inch of her, inside and out, with tungsten carbide blades. A big job but we did eventually get rid of all the loose rust, then we applied a rust converter, then red oxide, then bitumen.
As others have said, GET A SURVEY, but theres no reason not to buy if she's been well looked after.
  #27
Old 03-21-2012, 03:59 AM
They are basing that on the rivets being softer than the steel plate. However it only applies to flush rivets and they don't really erode significantly more although the operator should be made aware that they are softer.
We have sand blasted several riveted hulls and in my experience there is no appreciable problem. There are still quite a few small ships German built even into the 60's that have welded butts and riveted seams and they are routinely sand blasted, there is no other feasible commercial possibility.
As for rust converters , they are a very poor product and IMO should never be used on riveted hulls !
Mike Johns.
i have received the go-ahead to build another boat, need suggestions, think SOF thedutchtouch Boat Design 6 06-16-2011 09:23 PM
Steel Hulls ScottK Boat Design 12 02-01-2010 12:38 PM
good or bad boat? steel hull Razgo Boat Design 14 01-02-2008 12:11 AM
How to remove paint from the hull of a riveted aluminum boat? whalepass Metal Boat Building 3 04-24-2006 09:23 AM
Through hulls in steel boats tpierce Metal Boat Building 10 04-15-2006 04:40 PM
