Old 05-13-2011, 12:00 AM
Dean Smith Dean Smith is offline
Previous Member
Rep: 0 Posts: 0
oil hydraulics schematic ideas please
I am building a power pack
It,ll drive the ram for the horizontal press for shaping frames and will drive the motor for the plate wheels and or a special set rolls
I envisage quick couplings
I will use hose inside the tank so I do not need a removable lid but do it through the motor mtg cutout
The motor for wheels will be thus
pump of 6.4cc/rev @ 2000psi and 1450rpm = 2.9 hp 9.3lpm or 2.5 US gal/min)
motor (from tag 110cc/rev) we will get 76-80 rpm (depending on efficiency) and give 157ftlb of torque at 2000psi
Now these revolutions are too fast for wheel so I can either sprocket down or use flow valve?
i have schematic in mind, can anyone draw their ideas, perhaps someone in the industry?
thanks v muchely
here is tank and 2.2kw motor I managed to fold the tank and just had the butt weld and top. Maybe will mt on castors to take to each machine
Old 05-13-2011, 04:33 AM
Poida Poida is offline
Rep: 395 Posts: 1,072
Usually you have a removable lid for the tank for cleaning. Needs a filler cap of course that is vented so you don't pressurise the tank.
Now I assume that the pump is under the motor submerged in the oil. A pressure relief valve is sometimes incorporated in the pump setup but if not one will be required on the pressure side.
These units normally work on an open circuit ie. when the unit is not pressurising a cylinder etc. the oil circulates from the pump through an open valve back to the return pipe.
The return pipe has to be installed vertically into the tank to within around 50mm from the bottom. It is bad practice to have the return pipe above or near the surface to prevent aerating of the oil. A baffle plate is often placed between the return pipe and the pump to reduce aerated oil getting into the intake and any sediment stirred from the bottom.
A filter should be installed on the return line as well.
Because you are using the pump for two different things, it would be better to have the control valves on the machinery rather than on the power unit.
So for the power unit a pressure hose with a pressure relief valve with a female quick coupling on the end and a return pipe with a filter and male quick coupling.
Now the other information you have provided only dictates the speed your hydraulic motor is going to run at and the force and speed your ram is going to work at.
Old 05-13-2011, 04:44 AM
Previous Member
Rep: 0 Posts: 0
thank you Poida
yes the tank will be clean to start with, I made a few power packs dc for use on yacht winches etc
Have you got time to draw what you would do? How do you see volume throttling for the motor?
Old 05-14-2011, 01:57 AM
Adler's Avatar
Adler Adler is offline
Rep: 110 Posts: 98
Flow Control
Dear,
Try to install that:
http://www.brand-hyd.com/dc/dc-info.htm
It is the most efficient (cost/pressure drop) flow controller on the market's available.
Add to that your system could be have the necessary speed control you asked.
Old 05-14-2011, 03:06 AM
Previous Member
Rep: 0 Posts: 0
Originally Posted by Adler View Post
Dear,
hey Adler
thanks a lot I was about to go to a hydraulics forum.
Where is Gr are you>?
Old 05-14-2011, 01:08 PM
Adler's Avatar
Rep: 110 Posts: 98
Position
37° 57' 27" N
23° 36' 56" E
Old 05-14-2011, 04:28 PM
Previous Member
Rep: 0 Posts: 0
37° 57' 27" N
23° 36' 56" E
You are in a very shippy place indeed
look in you mail box
Old 05-14-2011, 06:57 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Yeah, this looks impressive: oil hydraulics schematic ideas please-pireas.jpg
Old 05-14-2011, 08:13 PM
Previous Member
Rep: 0 Posts: 0
Originally Posted by daiquiri View Post
Yeah, this looks impressive: Attachment 57143
It surely does
But where is the relief valve
I was Down in Gr in 06 drove down 2 of the 3 peninsulars, but that was as far S. as I made it Next time
Old 05-15-2011, 09:31 AM
Adler's Avatar
Rep: 110 Posts: 98
Information related to the thread
Dear,
Please see the following address:
http://www.engineeringtoolbox.com/hy...tems-t_59.html
See also your gmailbox.
Hydraulics Farley OnBoard Electronics & Controls 4 03-03-2011 10:03 AM
hand pump hydraulics summer suite Powerboats 2 10-12-2010 05:07 PM
oil hydraulics questions Guest62110524 Propulsion 3 06-20-2009 05:40 PM
Hydraulics: why not use water? chabrenas Boat Design 30 02-12-2009 08:39 AM
Low Pressure Hydraulics brian eiland Boat Design 1 07-29-2007 10:43 PM
