#106
| I just like to try to resume what I know from the thread: The vessel is wider, longer and is displacement is around 140 tons The engine room will 3 m high full beam, accessible from the interior corridor and deck The pilothouse will be 360 degree with head and sink. The owner room will be close to the point of least motion of the vessel The boat will be built of steel. Superstructure can be alu (I think) The generators are not important, can be replaced. Batteries is in, for silence and convenience The range is 5000 nm It will be go anywhere, built to ram a floating container at full speed. Ice resistant but not ice class. (I think I understood that way) The bulbous bow still in discussion but close to be scrap (I think, I am not sure) CPP mendatory (base of the whole concept of the vessel) One engine, one shaft, one wheel. Wet exhaust, or dry/wet exhaust, cooling not decided (I am right on this one?) Very efficient fuel polishing system. Tank testing is in. One model allready tested was refused. Naval architect will re-work the weight estimate due to increase of size. Engine was 25 liters displacement, can be larger due to increase of displacement from 100 tons to 140 tons. 5 tons was allowed for the mechanical, but can be increase. See above. A profile was shown, the vessel final profile will be close to the one posted. No nonsense vessel, comercial grade. The project attracted two interrested parties. The vessel as to be built with a sistership in the same time. The price will be 2.4 Euros for the new dimensions The resale value of the vessel will be not a major concern. I did'nt put in order, I just read again the whole thread taking notes. Did I miss or misenderstood some of the aspect of the project status? Cheers Daniel |
#107
How could you forget to mention my very sophisticated beef and beer cooling hold? Quote:
Say: Katuffel, Katuffel,Katuffel,Katuffel,Katuffel,Katuffel,Katuffel........ The best sound was made By the old Skoda, I can still hear them at the Bosphorus when some tiny old coaster is passing, music.......... Richard |
#108
| the majority of ships engines are of the crosshead 2 cycle type take a look, I think you are confused abt the type the type is the most mechanically efficient of any internal combustion engine up to 50% http://www.marinediesels.info/Basics...xplanation.htm go out and listen those engines you hear in the Bosperous arew cross heads, if you know your diesels and , then you can tell how many cyls they have, often they are 3 and 5, these have a beat of their own, and someone say torque Maximum power: 108,920 hp at 102 rpm Maximum torque: 5,608,312 lb/ft at 102rpm that is torque, follow the link and then there was the opposed piston eng Doxford, still in use many ships today http://www.youtube.com/watch?v=WKWOi0C-sak I have been to sea as engineer 2nd on small ships eng to 3000 shp , that was long time back, but large diesels I do have great love of I can see what a truly Great engine, these larger cummins are on the rivers of eu many of the old German engines are being replaced by American, cats cummins the long list of defunk companies goes on and on Carita originally had a pair of handed Paxmans 500 shp side Alaska diesel will one day be on that list, just another tiny maufacturer using Komatsu blocks |
#109
| [quote=whoosh;296342] Quote:
I am a advocate of the the bigger the better philosophy since ages, but within a sensible range. And Cummins is not within the range, the KTA 19 is too small, the 38 is a 12 cyl. and I do not have other than straight six as a propulsion thats a fact. And it is not worth discussing why, because every engineer knows. The ABC at 90 liter, the Yanmar at 50, the Mitsubishi at 35, are possible choices, yes. But the Lugger 6170 is not the worst choice, there is nothing wrong with the Komatsu base. All Pacific Northwest up and down, loves that engine and you find it in every second fishboat, why? Richard |
#110
| I was making atatement abt classes, 100-400, and so on, I was THEN not talking abt your boat, the fact is they were never made for smaller engines, the main advantahe being the huge stroke that could be obtained we were talking diesels, none of the stuff DAN POSTED WAS REVELANT to your boat in his last photo either threads lead places, we cant stay on one close parametre all the time , would be a dull lold place was yapping to a young NA in Tr today, told me abt this new marina, near Bodrum prces 14m berth 90 days 2400 euros, be empty a long time I would say i cant rememebr all i say, or where, I am really polite to you, try it )works well never knew abt Ice BREAKERS? which? where and when, thsi is a serious question Do you know the Krasnir? |
#111
| dskira "..No having often the fund to ask a proper tank testing facility to test, I use model, scaled on size and weight distribution, and tested here on the pound. Sometime self propelled. It is amazing how just that simple test will show me the main character of the hull..." It may surprise you but that is what my colleague and I do. My colleague has been doing this for over 40years, me just around 20. I am actually in the process of making my own test tank in my back garden, 25m long. Since i no longer have a pond close to me, nor my colleagues tank (he has one too). The models we make are identical, of course to the real thing, just as any full-on test house. Over the years we have found that our rough and ready tank test result are never more than 5% different with the real full blown expensive one we get done later to satisfy the contract for the client. We basically do exactly what Froude did many years ago...so not surprising the results are consistent. We offer this tank test service to anyone now...a quicker cheaper method of obtain results. |
#112
| Richard "...I choose for longevity, reliability and easy service!.." The customer is always right, whatever the numbers say....i also fully concur with your appraisal. Very very few customers select this route. Many opt for initial capital costs or rather the cheapest initial capitol costs. Only to their dismay and annoyance in the ensuing years or running costs. |
#113
Your post is so important to me. I was slighlty reluctant to post about that, knowing that sometime it's confused with playing with toy boat. Thank you, it make me very happy to know that you are also testing yourself your models. |
#114
| "...knowing that sometime it's confused with playing with toy boat..." We would always get funny looks from poeple (when we did this in the pond before using the tank in the back garden). Comments like..."oh..lovely...you with the model yacht club??"...or some walking by sniggering thinking, "sad grown ups playing with model boats". To the uninitiated, everything looks odd and of no use... Nice summary above, by the way. |
#115
And this is a thread about MY personal boat and a possible sistership. Here we discuss MY boat, MY diesel and MY issues and demands. When you doŽnt like that, I have no problem if you leave. But I have a problem with completely senseless crap like marinas in Bodrum or elsewhere. You claim to be polite??? This was your fifth or sixth attempt to hijack the thread. Quote:
The rest you could know since long, but as I said above, you doŽnt read a thread before you contradict. Quote:
But you know, greed is the motor of the business, stinginess and stupidity the fuel. So, let them buy the cr@p, and let me have what I want, peace in mind and smaller bills. (but bigger engines) Quote:
Regards Richard |
#116
| out of curiosity wouldn't it be simpler to have a return circuit tank where the water is circulated past the model one possible advantage would be that weights and balance could be changed simply by adding weights to rods that hold the model in place drag could be monitored by something as simple as a postal scale and accurately too thats the way boeings wind tunnel was set up water speed could be changed and a lengthly test performed without running back and forth baffles would be needed at both ends to smooth out water flow but these could be pvc pipe if this isnt clear i could do a sketch |
#117
| The benefits beeing as you said but some cons too. Slow to fire becouse it just takes more time to get water in motion than air. It also uses a lot more energy to keep it going. More eddies with water create some inaccuracy. |
#118
| Now after whoosh has failed again to hijack this thread, we should not make it the Tank Test Thread. I did express my dislike with whooshs attempts in a negative feedback. Can you imagine what this man offers here? Such a ship at that price is a gift. Even a plain commercial boat of that size will normally cost more. Sasha To remember what this thread was for: Quote:
#119
| I do not think anybody but you thinks that Sasha, and of course that ad zilch ad zilch, I say look to my gallery when I want to prove a point of to show folk, of course you are far to smallk to admite there is some nice work there AND YOUR work? none, you sit here all day with nothing better to do than pick holes you have a tiny following of beginners, the real nice poeple have long seen trhough you, the pros Saha, go to all my posts, I help all and 90 out of 100 appreciate that I have mail in my pc that would blow certain folks cred away in this thread but that is private and , so no I do not hijack theads at all, I could not care less what you or ad zilch say And you add zilch you are the guy who told bob to cut up a warped girder because it couid not ne saved, he did what I told him to do, and saved a lot of time and money You simply can not abide that I have you pegged )might add that I am proud of what I do, yes room to do better but thats what this site is all about boatbuilding and so far you have shown us TALK TALK TALK |
#120
| I agree with Sasha. Whoosh's post are always negative to anyone that disagrees with him or points out his prejudices etc or points out he is not contributing to a thread other than to say 'look in my gallery' or talks on subject totally unrelated merely to say 'look what i can do too'..... |
| one side plywood, one side fiberglass/epoxy, polystyrene core? | murv | Materials | 4 | 05-18-2007 08:06 PM |
| FSP "fiber spray putty" to build boats | pacoblasco | Materials | 10 | 12-09-2006 08:02 AM |
| canting keels: how are they displaced from side to side? | Thaddeus | Boat Design | 5 | 10-02-2005 05:22 PM |
| side by side centerboards? | Ian | Boat Design | 8 | 01-02-2005 09:24 PM |
| Trawler "Pandora" | Boat Design | 8 | 08-04-2004 02:56 PM | |
