Closed Thread
  #166
Old 09-07-2009, 06:59 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,694
Some of the 'higher end' engines provide this. We had all sorts of data/telemetry provided on a GT for a ferry we did. vibrations in mm/s vertical and horizontal acc's etc....since the engine wasn't cheap, this cost was peanuts in reality!..was cool watching on sea trails...but after than no one bothered!...of course until a problem occurs, which is where it is great...just print off the data.
  #167
Old 09-08-2009, 05:51 AM
apex1
This is a "high end" engine John! In fact it is nearly 3 meter high!
No, there will be no further complication added to a system choosen for its simplicity and reliability.
As mentioned, a camera is mandatory and sensible but nothing else.
You can hear when a ten tonnes system runs wrong, be sure. And the common setup of temp sensors tell you much too.
And although that is a UMS it does not mean the engineroom is not inspected regularely (hourly at sea).
All of you, who have ever been out at sea for long cruises under motor will confirm that one develops a sense for the ships noise in every sea condition. And you are immediately alerted when that pattern changes, even at sleep.
A bit aside:
I once had a couple of children as summer holiday guests aboard a old steamer. Their accommodation was below the foredeck, but the only head was amidships in the superstructure on the maindeck. My cabin was abaft the wheelhouse one deck above the main deck structure. There was a lot of noise when the boat was bumping against the pier fenders, when the passing ships made swell, the whining props, ropes under stress, and so on. When one of the children went to the loo at night I stood upright in my bed! I did hear the bare feet on the wooden deck, a noise which did not fit the pattern.
Richard
  #168
Old 09-08-2009, 05:57 AM
Naval Architect
Richard
I know what you mean... When on sea trials, going into the engine room, aft/jet void and even when in the saloon or up in the wheelhouse,....the vibrations felt, when 'wrong', are instantly recognisable as being 'wrong' and something is not right.
  #169
Old 09-08-2009, 06:34 AM
apex1
Some update on the engines:
these pictures show the same engines as a refit on the MS Balmoral.....here
Exhaust pipe! made at the yard
Cyl. Casting
Solid piece...
enjoy
  #170
Old 09-08-2009, 10:13 AM
wardd wardd is offline
Rep: 443 Posts: 925
my concept of simplicity is is at the bottom its as simple as can be to get the job done
take modern warships as an example chuck full of electronics and computers without which its a bobbing drifting object
so if anyone comes up with an efective jamming device and has old fashioned optical fire control wins the battle.
im not against computers, i assemble my own to get what i want
so when you have the base then adding layers of complex systems that can be isolated, i have no problem with that, ie its ok to have electronic engine control as long as theres a manual backup that can be imediately put into use
with mechanics you can diagnose a problem with a flash lite ( torch for our less civilized brethren) and 2 eyeballs, one eyeball if thats all you have
  #171
Old 09-08-2009, 03:13 PM
apex1
Whats a jamming device?
I agree that adding some gimmicks may be fun (and sensible too), but when you have followed the thread (and you did) you have noticed that I offer a 6 million boat at 2,4 million, maybe at the end it is a 7mio boat at 3mio. But there is not much space to play with toys at extra cost!?
Richard
  #172
Old 09-08-2009, 03:25 PM
Rep: 443 Posts: 925
my main point was take care of the basics first
  #173
Old 09-08-2009, 03:53 PM
apex1
Oh, yes I do, be sure! You might see that when you are thinking about my choosen engine!?!
Still doŽnt know what a jamming device is? Would you be so kind? DoŽnt let me die dumb.
  #174
Old 09-08-2009, 04:14 PM
Rep: 443 Posts: 925
something that would scramble all the electronics, such as a super directed emf pulse
not beyond possibility, it can be done on a small scale
put a calculator in a microwave and see if itll work after the smoke clears
  #175
Old 09-08-2009, 04:38 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
And that, wardd, is part of the reason I find Richard's focus on simplicity and mechanical reliability so refreshing.... that directed EMF pulse that screws up every electronic device within a hundred metres? Yup, lightning is exactly that.
Given the choice between a flashlight and a digital interface for troubleshooting purposes, I will almost always pick the former....
  #176
Old 09-09-2009, 05:22 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2006 Posts: 1,639
It would seem that there are many thousands of lightly used engines for sale in the world......
http://www.maritimeequipment.com/ShowAd.aspx?id=106022
  #177
Old 09-09-2009, 05:57 PM
apex1
That is right, thank you TAD! Here too:DIESELS
But (fortunately) not those old fashioned monsters like the ABC, Callesen or Grenaa. They last too long to be for sale!
And I will use the boat quite extensive all year round, so a new one is the better choice anyway.
Regards
Richard
  #178
Old 09-09-2009, 08:06 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Lots of monsters for sale here http://www.fornaes.dk/english/engines.php
Engine, gearbox, CPP prop, nozzle, thrusters, complete pilot houses!
  #179
Old 09-10-2009, 09:45 AM
apex1
Yeah, shipbreakers, they have it all. You know the "Alang Bazar" ?
Fornaes is a Neighbour of "Grenaa Diesels" in Grenaa, Denmark. And I am in Germany today, maybe I can manage to go up there tomorrow, have a look.
Regards
Richard
  #180
Old 09-10-2009, 07:02 PM
mgriffin mgriffin is offline
Previous Member
Rep: 92 Posts: 122
Apex, I might one day be as rich and smart as you if I become a successful boat builder. People pay a lot to have a 20 meter wooden boat custom built, and that way I could expand my company into a shipyard with the help of a loan. First thing I'm going to do when I have at least 10 million dollars, I am going to build a steamer of 66 meters in length, like the one in the picture. That will be my personal boat, and I am probably going to live on it. If you are still alive when I accomplish all of this, then me and you could team up. I build your ships, and you pay me.
Offer: true go anywhere Trawler to build "side by side"-smfreighter6.jpg
Closed Thread
one side plywood, one side fiberglass/epoxy, polystyrene core? murv Materials 4 05-18-2007 08:06 PM
FSP "fiber spray putty" to build boats pacoblasco Materials 10 12-09-2006 08:02 AM
canting keels: how are they displaced from side to side? Thaddeus Boat Design 5 10-02-2005 05:22 PM
side by side centerboards? Ian Boat Design 8 01-02-2005 09:24 PM
Trawler "Pandora" Boat Design 8 08-04-2004 02:56 PM
