| NEW! Metal Boat Maintenance Book-Download New book on Metal Boats-Download for 12 bucks, or you can read the complete book for free on the "preview" section of the book. See book here: http://stores.lulu.com/store.php?fAcctID=1427396 A do-it-yourself guide to metal boat repair and maintenance. Topic covered include, metal boat corrosion, metal preparation, interior rust, painting, extending the life of a steel boat, ultra-sonic metal thickness gauge use, changing hull plate and alternative methods of repairing metal boats. All presented in Scott’s east to understand language, giving you the tools to maintain your metal boat. Over 200 hundreds step by step photo descriptions to show clearly how to make permanent, inexpensive repairs NEW-See Our Earthrace Books and Yanmar second alternator mounts at: yachtwork.com Scott Fratcher Marine Engineer RYA Yachtmaster 200 ton sail/power/ocean/commercial Yachtwork.com Allison Thompson RYA Yachtmaster 200 ton sail/power/ocean/commercial 100 Ton USCG Captain Yachtwork.com +64 021 067 1528 001 415 287 3487 Copyright 2007 Without prejudice "What's important in life is not how many breaths we get to take, but those moments that take our breath away" Jaques Cousteau |
| Here is the table of contents of Metal Boat Maintenance Table of Contents Forward 7 Real Experience 8 Rescue a steel boat 14 Picking the boat to rescue 14 The boat not to pick 15 Pinholes 17 Movable Feast 17 Why repair this boat? 18 Surveying the hull 22 How long should a boat and paint system last? 22 Ultrasonic Metal thickness gauge 24 Picking a work location 25 Metal boat corrosion 26 Stray current (Electrolysis or Impressed current) vs. Galvanic Action 26 Induced Current 27 Testing for induced current 28 Cavitation 29 Crevice corrosion 30 Erosion Corrosion 30 Electrolyte corrosion 31 How much zinc is enough? 33 Weld on Zinc vs. bolt on zinc 35 Zinc block placement 37 Zinc bloc damage 39 Galvanic action examples 43 Aluminum pipe 49 Diluted phosphoric acid 51 Wood over metal 56 Mysteries 58 Performing a Corrosion survey on a metal hull 61 Performing a Corrosion survey on a metal hull 61 Tools needed 61 Locating stray current 61 An overall inspection of our project 62 Buying a steel boat 63 The answer 63 The first rust hole 63 Electrolysis hole in keel 64 Stern patch 64 Doubler plate 64 Second skin 69 Five year plan 70 Deck Leaks 70 The Five Year Plan 73 Making a metal boat last 100 years 74 Store the boat in fresh water 75 Keep the salt water out 75 Wash off the salt after a sail 75 Fix interior rust sooner than later 76 Search out ever dissimilar metal and study the effects 76 Keep the hull zincs new and test voltages with silver half cell 77 Search out any mill scale and eliminate it 77 Don’t grind 78 Remove rust and apply Amerseal primer at first sign of rust 78 Expect to spend a good two weeks to a month a year on hull maintenance 78 Build an easily removable interior 79 Perform regular corrosion surveys 79 Prepping the boat to begin restoration 80 Sandblasting 80 Soda Blasting 80 Water Blasting 81 Scraping 81 Scable Gun 81 Chipping Hammer 82 Air Chipping Hammer 82 Use of air chipping hammer 82 Grinding 83 Grinding tactics 83 Big Reach 83 Back Rest 83 Cup Brush 84 Flop disk 84 A typical prep and paint system 86 Painting 86 Paint type 86 Ameron Paint types 87 Paint world consolidation 87 Military surplus paint 88 Rubber paint 88 Aluminum Paints 89 Red lead 89 Zinc paint 90 Oil based paint 90 The most expensive paint? 91 Things have gotten better 91 Rust progression 91 Steel- How clean is clean enough 92 Applying the paint 92 Spray 92 Pressure pot 92 Gravity Feed HVLP 93 Ventura effect spray guns 93 Airless spray 93 Roll 93 Over Spray 94 Phosphoric acid treatment or not? 94 The acid test 94 How to rebuild a scable gun 95 How to rebuild an air hammer 98 How to remove a weld on zinc block when it was welded from the ends 99 Welding and cutting gear 99 Case Study#1 Cargo Ship 104 Tricky water line stripe 109 Case study #2-Photo essay of the strip, paint, test and repair of yacht Whatever 111 Quick grinding 115 Ultrasonic metal thickness gauge use 117 Grid the bottom 117 Verifying the ultrasonic gauge is working 119 Base line test for ultrasonic thickness test 120 Test #2 120 Test#3 121 Ultrasonic gauge reading through paint? 122 Ultronosonic gauge limitations 123 Measuring hull thickness behind a rib or stringer 123 Alternative methods of checking hull thickness 124 Tone tapping 124 Rinse the acid 124 First coat of paint 125 Test the hull thickness 126 Attach a ground to the hull 127 Regular patch 128 Marking the waterline 129 Mixing Amerseal 129 Rolling on the paint 129 Apply first coat of paint 132 Rub rails 133 A rusty hawse pipe 136 Bonding coat 137 Fill coat 137 Sand the fill 138 Fill pro and cons 138 Un-approved fill 139 Burned paint 140 Fixing interior rust 141 Grease in paint area 146 Mill scale 146 Anchor repair 148 Chain locker 148 How to change plate 151 Alaska bush method of plate change 153 A (more) proper plate change 154 How to add a through hull 158 How to repair a rusted away stringer 162 Patch or replace the port plate 162 Time between paint coats 165 Primer surface smoothness 165 Painting the new steel work 166 Welding a foamed hull 167 Bottom paint 169 Making bottom paint stick 169 Secret bottom paint additives 170 Painting the hardstand squares 171 After thoughts and tricks learned after the job 173 After the haul 173 Care for your neighbors 173 Cheap methods of boat cover 173 Scaffolding 174 Rolling stairs as work platform 175 Welding the engine shut? 177 Vinegar clean up 178 Live aboard in haul out? 180 What’s wrong with this photo? 181 Pulling you’re your gloves 181 Protect our body and health 183 Fresh air supply 184 Alternative methods of repairing steel 185 Thicker Steel? 185 Transducer failures 186 Cement 187 Tip-Removing poured cement 189 Fiberglass over the bottom 189 Wood 189 Emergency steel repairs 190 Chipped through the hull 190 Sharpened bolt repair 190 Splash zone 191 Spray Foam 191 Wet Patch 192 Welding under water and in a puddle and the rain 192 Appendix, notes, observations and final thoughts 194 Amerseal 194 Amerlock 2 194 When does a steel boat leak? 194 Paint thickness 194 Steel boats should look like a steel boat 195 PPG Ameron product data sheets 195 Index 196 |
| metal boat project 3 | Thunderhead19 | Metal Boat Building | 4 | 06-18-2009 01:09 AM |
| cruising costs, maintenance and price of the boat (sailboats versus motorboats) | Vega | Boat Design | 508 | 06-21-2007 07:11 PM |
| Metal Boat Project 2 | Thunderhead19 | Metal Boat Building | 12 | 10-20-2006 10:48 PM |
| metal boat project | Thunderhead19 | Metal Boat Building | 23 | 09-15-2006 12:15 AM |
| Repair & Maintenance book for a Sailing School | Gades | Fiberglass and Composite Boat Building | 0 | 12-29-2005 07:18 AM |
