Old 09-09-2008, 08:50 PM
bntii's Avatar
bntii bntii is online now
Rep: 943 Posts: 636
Need some advice on welding aluminum.
I have gotten up to speed tig welding stainless and have a Miller Maxstar 150 STH. I am going to build a boom and am wishing I had purchased one of the ac/dc machines to have the al capacity.
The question-
What are the chances I can decent results stick welding aluminum?
Thanks all
Old 09-09-2008, 09:00 PM
tazmann tazmann is offline
Rep: 192 Posts: 217
I have welded aluminum with stick in the past worked ok for welding flat but out of position gets a bit tricky. I would say get a few sticks and play with it on some scrap.
Tom
Old 09-10-2008, 03:42 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1544 Posts: 1,138
for starters, remove the oxidizing skin/layer from the alu before welding...
Wynand
A scatterling of Africa
Old 09-12-2008, 12:58 PM
kmorin kmorin is offline
Rep: 230 Posts: 185
Stick on Aluminum
bntii,
There are some aluminum flux coated electrodes in the market and they can make 'serviceable' welds, but they're not the type of cosmetically clean and full strength welds usually associated with a boom.
I'd suggest you find someone to use a TIG torch on the welds both for appearance and strength. AC TIG is the only real way to do the work you've described, other methods can be used but the welds will be second best -at best.
cheers,
kmorin
Old 09-17-2008, 07:01 PM
LyndonJ LyndonJ is offline
Rep: 233 Posts: 302
Would it be a possibility to use a stick with an onboard inerter for a handyman not a pro alloy welder to repair their own boat in an emergency patchup ?
Seems one of the pitfalls of alloy is doing repairs of fatigue cracks broken bits holed hulls etc in remote areas. I never heard of the stick welding..
What sized buzzbox-inverter (current/voltage) would be required?
Old 07-10-2009, 07:47 PM
gomoto69 gomoto69 is offline
Rep: 10 Posts: 3
apparently, you could tig it on dc, if you use helium for gas.
Welding Aluminum Pontoons ecoman Metal Boat Building 2 01-27-2008 12:56 AM
What should I use for welding Aluminum? CKP Metal Boat Building 6 03-03-2007 01:53 PM
MIG welding .080 5052 aluminum sheet Jack D Davis Metal Boat Building 2 09-26-2005 10:07 PM
New to welding Aluminum captain butch Metal Boat Building 22 11-28-2004 08:35 AM
Welding Speed for Aluminum Hulls jprev Metal Boat Building 3 11-06-2004 09:31 PM
