Old 05-22-2006, 08:14 PM
Thaddeus Thaddeus is offline
Eccentric
Rep: 10 Posts: 24
Location: 44.93N -93.13W.. not far from the Sweetwater Sea
Need advice on seam sealant for riveted aluminum sailboat
Hi,
I am building a fast sailing dinghy out of aluminum. I am using an aluminum canoe hull as the basis. Pics at http://www.tc.umn.edu/~austi012/sailboat2.htm.
I am waiting for my special order rivets to arrive, so I have some time; but I am uncertain what sort of sealant to use on the seams. Can anybody suggest something? It almost looks as though Alumacraft used pipe dope on the original seams. I'd need something tough, watertight, resilient, and resistant to extremes of temperature, and of course it should stick to aluminum.. Would something else be a better choice? Silicone caulk, perhaps?
Thanks in advance for any help anybody might be able to provide.
cheers
Thaddeus
Edit/Delete Message
Old 05-22-2006, 08:44 PM
Rep: 1729 Posts: 2,462
Thaddeus
I have found Polyurethane sealant to work well in this application.
Cheers
Mike Johns.
Old 05-22-2006, 08:54 PM
Eccentric
Rep: 10 Posts: 24
Mike,
The stuff I am thinking about is sandwiched between the 2 aluminum plates where they are riveted together, and acts like a gasket. Is there a polyurethane substance that serves this purpose? If so, can you direct me to a supplier's web site?
Thanks.
Thaddeus
Old 05-22-2006, 09:16 PM
radar radar is offline
Rep: 10 Posts: 3
http://www.royaladhesives.com/brand.asp?division_id=4 Thaddeus,hello from Canada.Check out this website.We use this product to repair aluminum shipping containers.It works very well.HOPE THIS HELPS,radar
Old 05-23-2006, 02:32 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
Sikaflex 292 or 3M 5200.....
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 05-23-2006, 03:17 PM
Eccentric
Rep: 10 Posts: 24
Why the "uhhhg..." in the duplicate thread, Thunderhead?
btw, ordered the 5200..
Old 05-23-2006, 07:24 PM
Originally Posted by Thaddeus
Mike,
Thanks.
Thaddeus
Yes thats what I was expecting. Check that the sealant will adhere to Al in salt water with the manufacturer. In reality I have often used the cheapest Building grade sealant and found that it sticks with unbelievable strength for years.
As thunderhead says the 5200 is a pretty good gloop
Can make a hellava mess though.
Mike Johns.
Old 05-23-2006, 09:38 PM
Eccentric
Rep: 10 Posts: 24
Salt water? You think I'm taking a 16 foot aluminum sailing dinghy into salt water?
NO WAY
Old 05-25-2006, 07:43 PM
Rep: 21 Posts: 504
Uhhg: Canadian English, meaning "everyone I've ever worked with and for would be embarrased to use the 'R' word". But I changed my mind by the time I posted here....
JDF
Old 05-25-2006, 07:54 PM
Eccentric
Rep: 10 Posts: 24
It's going to be pretty impressive for a first effort at boatbuilding despite the use of rivets, I think. We'll see.
I intend to embarass some Vanguard 470's with my little craft.
Old 05-28-2006, 09:09 AM
MATTEOPASSONI MATTEOPASSONI is offline
Question
I'm very much interesting in your 20' central canada police boat, do you have some more info or drawings ?
hti.it@tin.it
Thank You, Mat.
Need help choosing seam sealant on aluminum sailboat Thaddeus Boat Design 7 06-11-2006 10:48 PM
How to remove paint from the hull of a riveted aluminum boat? whalepass Metal Boat Building 3 04-24-2006 09:23 AM
Looking for Boatbuilder for aluminum sailboat - Canada Erik Services & Employment 15 02-16-2005 09:38 AM
Aluminum Cruising Sailboat Construction MikeQ Metal Boat Building 7 02-14-2005 02:45 PM
Want advice on submitting some radical sailboat/powerboat designs to industry Marcum Marine Boat Design 5 11-16-2001 06:18 AM
