#46
| UPDATE!! The boat is done!!! A little over a year after the first cut this project is finally over. The actual time spent working on this project was short. I'm guessing about 30 hours of work. I had the hull cut and welded in one evening, then about a year later I added the flotation compartments and painted everything with in two weekends of work. I brought a GPS with me to see how fast I could go...it was a little disapointing. I could cruise at 3.5 with little effort. To get to 4.5 I had to really put some muscle into it. I was expecting a cruising speed of 4 knots. Sometimes its better not knowing I think. I decided to add a sail rig to it, just because I had an old snark lateen rig laying around. No centerboard or daggerboard though. The boat really is for down wind only, originally I was just going to use it in rivers, but I thought some versatility would be nice. The sail worked way better than I thought. I could easily ghost along at 2 knots even though I could only feel the faintest breeze. Later the wind piped up a bit and I was able to do 5.5-6. I was even to able to sail upwind when it got gusty. I was really surprised how well I could up wind with no board of any kind. All it took was some induced heel. When I say up wind really I mean at about 70 to 80 degrees off the wind, still able to point way higher than I would have guessed. ![]() ![]() ![]() ![]() |
#47
| The performance would be about right for a heavy 11ft boat with canoe ends. Sometime in the future, you might be able to take advantage of steels greatest ability - cut it in half and add another 4 ft in the centre - so much easier to do in steel than any other material, It would make the performance significantly better, while only adding to the weight by a little. |
#48
| A very nice looking boat, with that charming utilitarian look some small boats wear so well. And just think, it could be around for a long time to come.
__________________ Cameron D. M.M. |
#49
| what software used to do this metal sheet boat ? |
#50
| Great Job! Hi, I was wondering if you'd be willing to share the plans for this boat? I have just found a sheet of stainless in my stores and would love to put it to good use - I can't think of anything better than this! I'd be happy to credit you in the build and send you pictures of the finished article. If not, I completely understand - could you tell me the name of the software that you used? All the best, James |
#51
| I'd be fine in sharing the plans. Just PM me your email address and I'll send you the files. I used carlson hull designer and freeship software to design the boat. I would however suggest making some changes to the design as I have found the most comfortable seating position is too far forward of the center of buoyancy. I would also add a bit more flare to the top, thats just me though. This should be an easy fix, and half the fun of building a boat is designing it. I made countless paper models before I settled. |
#52
| plans... Hi Hobo - I'm so new I'm not even sure how to PM you! My email is james (at) globecycle (dot) org - I have no fear of others knowing this address! Many thanks and I will keep you updated. J |
#53
| Any photos of you sailing her, hobo_hut? Most impressive! |
#54
| The boat looks great. As long as you maintain the paint it should last forever. C.O. http://whatsintheshop.blogspot.com/ |
#55
| No photos of the sailing rig yet. Ive ditched the old sunfish rig and have made a new balance lug rig with more area. Also all the spars fit in the boat now which is much nicer and I should get even better light air performance. I won't have photos of the rig for awhile as its now bitterly cold here. Hopefully we will get a break and I can go out and take some photos so you all aren't waiting for the next three months. |
| What is this metal sheet for? | Ric.H | Jet Drives | 2 | 04-23-2008 01:27 AM |
| sheet PVC | John P | Materials | 2 | 12-19-2005 06:52 PM |
| new free design & building project: YAGO 31' steel origami yawl | yago | Boat Design | 1 | 08-21-2004 12:42 AM |
| Unfolding formed boat panels to flat sheet | Rohan_Tink | Metal Boat Building | 3 | 02-23-2004 10:02 PM |
| Looking for lot near San Diego for 1924 steel yawl project | jdardozzi | Boatbuilding | 0 | 06-01-2002 09:44 PM |
