Old 06-14-2009, 03:55 PM
M&M Ovenden M&M Ovenden is offline
Rep: 527 Posts: 183
Moisture cured urethane paint
Hi,
It looks like moisture cured paints are gaining popularity in industrial applications. I was wondering if anybody has used this type of paint on any steel boat projects ?
example: (but not the only manufacture)
www.mcucoatings.com
I'm wondering if MCU's are sold on how well they protect vs how they can be applied in tougher environments & with lower VOCs.
Cheers,
Mark
Old 06-15-2009, 03:38 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,144
Whole offshore platforms have been painted with that, so it will also be good for your steel hull. But bear in mind that the keyword is moisture, not water, rain etc. The surface needs to be dry and clean like for any other paint system, the moisture in the air replaces the hardener/catalyst.
Old 06-15-2009, 04:09 AM
mark775
Impressive advertised properties. I'll try to find some and try.
Old 06-24-2009, 08:41 PM
Rep: 1623 Posts: 2,343
IMHO the success or failure of a paint coating is very much related to the thickness of the coating. Thin coats are often easily compromised no matter how tough the paint every little impurity dust particle or discontinuity becomes a little stress riser which in a thin coating leads to local failure. Anodic protection speeds up this failure through cathodic paint disbondment.
A big advantage of epoxies is a high build thickness with each coat. Some of the epoxies are now applied with coatings up to 3mm with each application and this is common in demanding marine environments. Building up 150 microns with several coats is never going to be as good as applying 1000 microns and I really doubt you'll ever see urethanes as an economic or effective base coat on commercial submerged structures.
cheers
Mike Johns.
Uv light cured resins ? pescaloco Fiberglass and Composite Boat Building 5 06-03-2009 10:14 AM
Mist before epoxy cured tuantom Fiberglass and Composite Boat Building 12 05-06-2009 12:24 AM
Paint over spar urethane on plywood. rmcelroy Materials 2 06-19-2006 08:09 AM
How to/best way to touch up urethane paint runs…? paularey Fiberglass and Composite Boat Building 6 11-28-2005 05:50 PM
UV light cured resin TheFisher Fiberglass and Composite Boat Building 0 06-17-2004 01:39 PM
