Old 10-03-2006, 08:13 AM
zeljkomrsic zeljkomrsic is offline
Rep: 10 Posts: 8
minimum size steel?
I'am new on the forum. Sorry on my bad English grammar-Thanks!
What is the smallest size of steel boat what we can built (houseboat)?
I hope you understand me!
Old 10-03-2006, 08:31 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Steel construction doesn't really have a lower size limit.... well, it does, but it's pretty darn tiny. You could build a 4-millimetre boat out of steel if you wanted to.
What's the intended use of the boat? How many crew, what kind of sea and wind conditions?
Old 10-03-2006, 01:05 PM
Rep: 10 Posts: 8
you are right!
Hmm, yes you are right.
I want to make small boat from 5 to 7 meter (about 20 foot) for the first time? I live in Croatia, we have many island and many bays, the sea and wind is silent.
May I make boat of this size? What is the thickness of hull (steel)? We have many boats in our town but I didn't find steel boat this size. I find aluminium small boats but I want steel?
Thanks!
Old 10-04-2006, 06:02 AM
martinjancar martinjancar is offline
Rep: 10 Posts: 2
I have a steel boat of type Wibo 740. It is located in Pula. If you wish more information, just send an e-mail on martinjancar@yahoo.com.
Old 10-04-2006, 10:15 AM
marshmat's Avatar
Zel- the simple answer is yes; how heavy you make the plating depends on how the structure is set up and how much abuse it will have to take. Will it be used as a workboat, or just for fishing from.... will it be hauled out on rocks..... how much speed/power do you need.... Take a good hard look at how you'll use the boat, and with whom, before you commit to anything.
Old 10-04-2006, 10:57 AM
Rep: 10 Posts: 8
Thanks marshmat!
Mars_ Thanks you!
I find some information, Martinjancar help me lots. I don't decide yet what technic to use. Martin have boat Wibo 740 7 meter, loks verry good.
Thanks you again and sorry on my bad English grammar!
Old 10-04-2006, 12:25 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
4mm plate actually builds large boats....
The Dix 65 (Lorrigray featured in Dix's webpage) I built was with 4mm plate on entire hull sans keel and 3mm on deck.
Incidently, the Dix 57, Dix 38 (frameless) v/d Stads 34 / 40's were built of the same combination ; 4mm hull & 3mm deck
I also built a few Tom Thumb 24's (Grahaeme Shannon designed) frameless method, 3mm plate on hull, keel and deck and they were extremely strong - one even done a circumnavigation.
OTOH, I designed a little pocket 23ft steel cruiser similar to TT24 with a very light but strong frame, plated with 2.5mm hull and 1.6mm deck plating. To make it last is a question of an extremely carefull applied epoxy paint system
Wynand
A scatterling of Africa
Old 10-04-2006, 12:47 PM
Rep: 10 Posts: 8
Wynand,
Do you have picture of 23ft steel cruiser similar to TT24?
Do you make frame with 2,5mm?
How you weld steel 2,5mm, with electrode or gass?
Thanks!
Old 10-04-2006, 02:08 PM
Wynand N's Avatar
Zel,
Unfortunately the design was done on AO sized plan paper and I must get it redused for posting and do not have the facilities closeby to do it now.
But I include a picture of my Tom Thumb 24 under construction many moons ago and she have since done a circumnavigation with her current owner.
My design looks 90% like her but the main difference is that it is raduised chine whereas the TT24 is multichined.
No, the framing is 40 x 6m transverse frames with 25 x 5mm longitudinal stringers and the keel area have 4mm transverse reinforcing/floors.
Do not bring a gas welding unit near steel!! It will overheat and distort the plates as it is a very slow process.
Rather use arc (electrode) welding although I personally prefer the Mig Co2 welding process.
Wynand
Old 10-04-2006, 02:46 PM
Richard Hillsid Richard Hillsid is offline
Rep: 19 Posts: 117
THIS one is good bought the drawings, made model but never built it.
Old 10-04-2006, 03:05 PM
Rep: 10 Posts: 8
Thanks Wynand,
verry kind from you
Minimum coaming height fede Boat Design 2 01-04-2006 10:44 AM
Minimum practical thickness of aluminium? Raggi_Thor Metal Boat Building 5 12-17-2005 06:52 PM
Full size patterns or 'lofting' for steel boat? Luc N Metal Boat Building 8 05-11-2005 11:55 AM
What happens if I increase the size of the boat by 30% than the intented size abrahamg Boat Design 6 04-26-2005 06:09 PM
Minimum wire size arjan Electrical Systems 9 02-19-2005 09:49 PM
