Old 12-14-2005, 02:08 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Minimum practical thickness of aluminium?
What is the minimum practical thickness of aluminium?
It seems like even the smallest boats are built of minimum 2mm alu?
I ask because "aitchem" asked for an aluminium version of the Backman 18.
I have always thought that for small light boats it's the local stiffness that is the dimensioning factor while for large (long) heavy boats you also have to look at the global stiffness (the hull as a beam supported at each end).
If 6mm plywood at 3kg/m2 is a practical minimum, I can't see how small aluminium boats can be as light as a plywood boat.
Any comments from the metal boat builders?
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 12-15-2005, 04:15 PM
Raggi_Thor's Avatar
Did I post to the wrong forum?
Is 3mm the minimum practical thickness to weld?
www.MBOATS.no
Old 12-15-2005, 04:38 PM
alyne alyne is offline
Rep: 38 Posts: 45
Not sure about sheet alluminium, but I have just had a frame tig welded together using 16guage (approx 1.6mm) thick aluminium tubing. Worked a treat!
Old 12-15-2005, 11:48 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
Being able to weld it is the real issue on small boats. Riveted hulls can be as thin as 1mm. 3mm makes a good easily, inexpensively, weldable, durable hull, 4mm and you can go ramming other boats.. well not quite..
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 12-16-2005, 03:46 AM
Raggi_Thor's Avatar
Thanks to both of you, maybe riveting or gluing is the way to go in very small boats?
www.MBOATS.no
Old 12-17-2005, 06:52 PM
Rep: 1493 Posts: 7,447
Palmer Johnson used to build 12M boats in glued, lapped aluminum.
How do you Determine Composite Thickness? solarboater Fiberglass and Composite Boat Building 4 03-31-2011 09:09 AM
TIG or MIG for Aluminium? ted655 Metal Boat Building 16 01-22-2006 12:58 AM
keel fin thickness usa2 Sailboats 14 12-05-2005 03:22 AM
Aluminium or Fiberglass speedboat? Baneng Materials 9 11-07-2005 06:27 AM
Pros and Cons of Transom Hung Rudders Gone Ballistic Sailboats 19 09-19-2005 08:15 PM
