Old 05-29-2008, 07:19 PM
o2bfishn o2bfishn is offline
military bidge boat the transom has no angle what is the best way to attach outboard?
I have a military bridge boat that is 19 feet long 7 feet wide and 24 inch deep at the transom. Plus the transom is 90 degrees.
These boat were designed to be a float bridge. 2 boats bolted together by the transom and bridge road bed attached on top. If you have seen the movie "kelly's hero's" starring Clint Eastwood they drove a tank over one.
The problem I have is: What is the best way to put a motor on the back with such a steep angle and height.
I have attched some pictures from a Vietnam web site that shows 2 50 horse power motors on it.
Thank you for your idea's
military bidge boat the transom has no angle what is the best way to attach outboard?-boat1.gif  military bidge boat the transom has no angle what is the best way to attach outboard?-boat7.gif  military bidge boat the transom has no angle what is the best way to attach outboard?-boat.gif
Old 05-29-2008, 10:02 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
Well, first of all, welcome to bd.net
Most outboards you find now will probably be set up for a transom raked aft around twelve degrees, give or take a few degrees. Sterndrives are in the same ballpark; jet drives are generally available in 0 or 5 degrees.
Depending on the outboard, its lowest trim setting might give an acceptable thrust line (ie, near parallel to the bottom) with the current, 0-degree transom. Other outboards might trim out too much even fully tucked in. If that's the case for your chosen setup, probably the easiest solution would be to fabricate a setback bracket at a suitable angle, bolt it to the transom, and clamp/bolt the outboard to the bracket. In steel this could be done for less than a hundred bucks if you can cut/weld it yourself; fibreglass is also an option. This way, you don't compromise the original boat (esp. its structural integrity) at all, and you have more freedom to optimize the motor placement.
Old 05-30-2008, 12:13 AM
charmc charmc is offline
Rep: 833 Posts: 2,390
Welcome aboard!
A setback mounting bracket is probably your best bet, allowing you maximum flexibility. Matt has summarized the details very well.
Good luck with your project.
Best,
Charlie
Old 06-18-2008, 11:26 AM
Lt. Holden Lt. Holden is offline
Rep: 20 Posts: 137
Does it have the M-60 on it, Cool!
Transom Reinforcement for Outboard Conversion Jim Williams Boat Design 25 10-04-2009 11:38 PM
how to design the transom angle with suzuki 300hp nemo4653 Outboards 1 08-22-2007 08:30 AM
Transom reinforcing 34 Silverton for outboard conversion naturewaterboy Fiberglass and Composite Boat Building 18 07-16-2007 08:23 PM
Transom thickness for outboard motor 100 to 250 hp hseneque Boatbuilding 2 08-19-2005 12:39 PM
What is transom angle? chase687 Boat Design 4 06-29-2005 02:21 PM
