Old 09-04-2011, 03:51 AM
pdwiley pdwiley is offline
Rep: 531 Posts: 489
Originally Posted by Katoh View Post
The biggest hassle with the spool gun is finding the spools, and expensive to-boot. I'm thinking I might buy a 6kg roll and make a unit were I can just re-roll the used spools. I look at it like this, If you run out of line on your fishing reel you don't buy another reel, do you? The only thing is I would either have to guide the vire with a cloth or gloves so not to contaminate it.
Friend of mine does that and says it works fine. He uses a lathe on slow speed to spin the small spool and guides the wire using a stick with a hole in it. This for flux cored wire.
While I do have a spool gun I prefer to use the gun that gets fed from the 15kg wire spool but my MIG only weighs 40 kg with its wire spool and I lift it on the gantry if I have to. Different story with the big old transformer units.
PDW
Old 09-04-2011, 09:03 AM
Katoh Katoh is offline
Rep: 58 Posts: 196
PDW
Great Idea, love the stick part keep the hands and contaminates off the wire. I have a spare lathe could be just the ticket.
Don't think Ill be lifting that old mig must weigh 60kg empty, plus my project is outside, no gantries to hang off.
Thanks
Cheers
Katoh
I maybe slow, but by crikey I'm rough
Old 09-04-2011, 07:36 PM
Rep: 531 Posts: 489
You're welding aluminium IIRC. I'd probably use a piece of UHMW (white plastic breadboard) as the wire guide.
Put a brake on the big spool so it can't overrun. A spring bearing on the side of the spool is probably enough.
I built my workshop first, then the gantry setup, then the steel grid base and only after all that I started on the boat.
PDW
PDW
Thanks
CFD Analysis: Meshing Woes dtoshni Software 0 06-03-2009 05:38 AM
Quadrajet carb woes, help! manzanita Gas Engines 8 04-19-2007 02:56 AM
Solara AG Solar Panel Warranty Woes geoffschultz Electrical Systems 12 03-07-2007 02:50 AM
New Genset Woes - Who To Advise re Design Defect? elmaceh Open Discussion: All Things Boats & Boating 8 04-21-2006 07:26 AM
mig rico Marketplace 0 04-30-2005 02:01 AM
