Old 09-16-2006, 03:39 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Originally Posted by MikeJohns
...units units units ! how about a few ^2 on some of those mm and m. You'll make life simpler for the quick casual reviewer..... busy
Yes :-)
I often write m2 and mm2 or mm4 when I mean m^2, mm^2 and mm^4.
It saves time....
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 09-16-2006, 07:51 PM
Rep: 1623 Posts: 2,343
Ragnar
I was refering to your spreadsheet (N/m) (N/mm) toungue in cheek.
Thanks for your input
Mike
Mike Johns.
Old 09-16-2006, 08:17 PM
george allard george allard is offline
Rep: 7 Posts: 61
<off-topic personal insult removed by forum moderator>
You can bend a steel plate 720 dregrees and it will still work.
Old 09-17-2006, 12:23 AM
George Allard
Ragnar is certainly a knowledgable peer and I was engaging in some friendly banter. It is often hard to properly construe the true nature of written messages. Which is why the little faces are there.
As an engineeer I design but I do not have much experience of building; yards have their own approach and often very helpful rules of thumb. The steel plate is to be sent off to a remote area and since 8mm is a bit on the thick side I needed to know whether to get it pre-rolled or whether they could pull it to shape easily without distortion.
Murielle is using 5mm plate which is a little different. Raggi’s approach is back to basics which is refreshing , but I have been bitten before with what you should be able to do and what a boilermaker is happy doing.
I browse the boatdesign website while working and often have little time to thoroughly read through the math. Having taught engineering in the dim past I always scan through the units to check a calculation, hence what may appear a rather brusque response which was supposed to be a humorous ‘see me after class’ approach.
In future please keep your posts devoid of personal insult. Your input re 720 degrees is also unhelpful . We could do with better posts than this, I look forward to your next effort.
Mike Johns.
welding steel plate on a keel lockd Metal Boat Building 4 11-10-2005 06:50 AM
Steel plate thickness Ron Cook Metal Boat Building 10 03-05-2005 04:39 PM
GZ curve ivansalasj Sailboats 7 02-23-2005 01:51 PM
Steel plate Thickness LowcountryData Sailboats 29 11-30-2004 04:17 PM
propellor-curve? Guest Powerboats 0 11-06-2003 06:07 AM
