| Junk Rig Sails I want to outfit our boat with the Chinese Junk Rig. I am looking at a double masted design, with equal sized sails if possible. Although, I am not adverse to a smaller sail up front. Does anyone have any information on calculating mast locations for this rig? I understand that there is a WHOLE LOT of physics involved with this. My boat is 40' long, and steel. I've got plans for a similar boat made of wood of the same lenght. Could the sail plans for that boat be used??? Thanks! Kevin. 1/ Boat is hole in the water you throw money into 2/ House is hole in the ground you throw money into. 3/ Car is box in driveway you throw money into. Wife is Queen you give money to in order to carry on performing the first 3 tasks. |
| Kevin Best to re post this question in the boat design section. cheers
| I want to outfit our boat with the Chinese Junk Rig. WHY , are you going to limit yourself to following the Monsoons downwind as the rig is designed to do? Do you like to play with a dozen lines (Snotters) on every tack? A modern full battened main is far and away a better sailing companion when made of dacron. If all you can get is old rice bags , the Junk rig might be more suitable, but for a sail loft bought setup the hassles and total loss of performance should be considered. FAST FRED |
| Junk sails are self tending when well designed. You don't touch anything unless there is the need to reef or shake a reef. The calculations are not different from any other kind of rig. However, you need to have the hull lines, true displacement and trim to do so.
__________________ Gonzo |
| Tuitorial on Chinese Sail Link Here are some article on chinese look alike sail.......... I think........... ![]() Odd Sails from Polytarp http://www2.friend.ly.net/~dadadata/oddsails.html BATWING SAIL http://www2.friend.ly.net/~dadadata/...Bat_Sails.html Ruston Batwing Spars http://www2.friend.ly.net/~dadadata/...Bat_Spars.html Junk Sail Tuitoral ![]() ![]() ![]() http://www2.friend.ly.net/~dadadata/junk/tutorial.html Sorry , I post too much JUNK....... that why this is a JUNK Thread ![]() ![]() ![]() |
| Aftmast rigs??? | jdardozzi | Sailboats | 486 | 01-28-2012 06:17 PM |
| Sail Loading on Rig, Rig Loading on Vessel | brian eiland | Sailboats | 93 | 02-23-2011 08:19 PM |
| Chinese Junk Rig | Wynand N | Sailboats | 27 | 12-27-2009 04:43 PM |
| Motor Sailors | dlynch | Motorsailers | 15 | 04-06-2005 04:16 AM |
| FEA of sails and rig | MikeJohns | Software | 3 | 10-16-2004 06:19 AM |
